Diesel Cayenne and VW emission issue
#5176
We had some "new stuff" burning smell for a couple of days with the '14, but didn't really notice anything on the '15. Might have been there, but since the '14 was first, it may have just been normal and unremarkable to me by then.
#5179
#5180
#5181
Had the modifications done to my 2013 CD on 1/18 -- so far so good as far as the vehicle's behavior is concerned. As documented in the booklet Porsche sent, the engine braking going downhill is less (pretty much non-existent), requiring use of the brakes more than before, engine sounds slightly different, power seems about the same, and shifting behavior seems fine. Haven't noticed any warm-up issues (temps in Newport are normally mid 60's to 70's). Have driven about 100 miles over the past couple of days
Work was performed at the Newport Beach Porsche dealer. Loaner was provided, vehicle received an exterior only wash, gas gauge was slightly above 1/2 full when I picked it up (Porsche clearly states that "a full tank of fuel" is included with this modification -- page 9 of booklet). Was not offered delivery of the vehicle upon completion, as promised in the booklet. And upon opening the rear hatch, my wife noticed crusty dried-on white stuff on the metal strip near the rear hatch latch; the white stuff had a trail that led to the adblue tank -- looks like DEF spill. Took pictures, then cleaned it. I am purposely sticking to the facts, and not offering any personal opinions of this service visit; my expectations may differ from yours, and / or the Dealers.
#5182
Thanks 911howl. My smell went away as well but now that I think back it must have been related to the regular service done at the same time. If MY15 is just the SW update then there shouldn't be anything new to smell.
After a week or so, post fix, not certain how I will see the MPG that I had been getting before. Holding 7th gear longer, holding lower gears when cold, and so on. I use to be able to get 31mpg on any drive longer than 15mi (20/80 street to hwy) using good mileage practices (not spirited). I understand that the data is only partly empirical but my average now is closer to 28. Not certain how others see anything over 35 as I practice "safer" hypermiling (sp) techniques. I've also observed that my first few miles out of the house seem to be a higher mpg than before.
If somebody reading this forum has not done the fix yet I would be curious of your before/after experience in the first mile or so leaving your house. It can be a predictable mile as the stops signs, traffic, time of day when you leave and so on are pretty consistent.
#5183
Ok I discovered my VAG-COM will datalog boost, EGT, etc. The sample rate sucks (2-3Hz) but its interesting enough to look at.
I did some 3rd gear runs... logged RPM, EGT and Boost. Accelerate from a stop with the trans in "automatic" until it shifts to third, then flip the shift lever over to manual, slow down to 1200rpm or so... and floor it (but don't hit the kick-down switch).
Peak boost ~23psi (the 260kPa number is "absolute" so need to subtract 100kPa for atmospheric pressure) up to around 3000rpm where it falls (as reported here already) down to 15. Peak EGT 783C (1440F) at 4500rpm.
Did a few runs and the data is pretty consistent.
Standard cruise at 55mph is around 3psi boost and 400C (750F) EGTs.
Wish I'd have realized the VC would log this or I'd have happily taken before/after fix logs.
#5184
Today I received two packages in the mail. Both were from Porsche, welcome kit. One for my 2016 "Unpunched" Cayenne Diesel (CD) and the other for my 991.2 GT3. The package contains a brochure and a small hardbound book about the car you just bought. I like the carbon fiber pen. Nice thank you gift from Porsche.
Drive safe,
GT3RS-Fan1
One for the Cayenne Diesel, the other for my 991.2 GT3
Cayenne packet
Brochure, small hardbound book, and Carbon fiber pen
Drive safe,
GT3RS-Fan1
Cayenne packet
#5185
Anyway, I picked up a OBDlink LX, and the refresh rate isn't MUCH better than that, and the OBDlink is known to have the best PID read rate around. I'm looking forward to having this additional info on-screen when I'm towing. In Torque, I made a little dashboard for Transmission temp, Intake air temp, Boost, and EGT's that I'll leave up. I'm wondering what the trans temp will be. Running around empty, whether in traffic or flogging it, it stays right at 200° F, so whatever regulation system is in play here is working very well! (I have the 12:00 position of that gauge set at 225° - anything less than that and I'm not worried.
#5186
Drive safe,
GT3RS-Fan1
Cayenne packet
Drive safe,
GT3RS-Fan1
Cayenne packet
Somewhere, I have one of the original VAG-COM's, that used a RJ-45 connector.. Used it when I had my '97 Audi. I remember (nostalgically) plugging into the car and then dragging 100' of cat5 upstairs to where my PC was to scan the car.. (Laptops were really expensive then!)
Ya know I didn't look to see if it has trans temp available. Something I've been interested in monitoring when towing. Tho VAG-COM doesn't exactly make it easy to read while driving. When logging I use a Windows tablet, which I originally purchased for logging on my old 944 Turbo (software had a nice "gauge" display).
#5187
Torque dash..
#5188
I like it.... nice.
I wonder if the iPhone version is as nice/configurable? Reviews for iOS Torque are not as good as Android versions.
In other news... like I need another hole in my head... I'd talked myself off the ledge of trading my '14 for a '15+. Then I read the new CPO warranty is unlimited miles. I put about 35k/yr on my cars so that warranty is tempting.
Then I find a local dealer has a '15 CD, 9k miles, listed officially as CPO, loaded, PP+, hitch.... PLUS Burmester (which is a big want....) Ad says "Warranty until 2023" though the build sheet says "2021" so not sure on that....
But unlimited miles and warrantied to 2023 is tempting.
#5189
I like it.... nice.
#5190
Unlimited miles?!?!? Wow.. That would have been tempting when I was shopping.
I found the one you're talking about - That's a nice one! Tempting.. The Burmester is even more of a pipe dream when I was looking than Air suspension!
If you go that route, I found a nice deal on a set of new 20" RS spyder wheels ...
