Mr12Volt - The solution for Carplay and Android Auto integration
#421
Final question. I have tested everything and it’s working great. I just need to put the PCM back into its place. However, I have been trying for at least an hour and I cannot for the life of me get the cables to fit back in. I can’t push the pcm in the final centimeter or so and again don’t want to break anything. Again it’s a 2010 Cayenne gts with PCM 3.0. Any tips for getting this thing to fit?
#423
#424
In case anyone wants to change their startup logo to something else, here are few that I created. Both are 800 x 480 pixels and have been successfully tested to work in my car.
If you want the Cayenne silhouette as your logo, here is the one originally posted by @twodollardoug (I have darkened it to blend it better with the OEM startup graphics):
Mirrorslap (09-09-2024)
#426
By "change" you mean replace phones for good or switching between multiple paired phones?
#428
It is annoying. I don't do it often but my girl friend likes to have hers connected on road tips. It is always a process; I have to turn off Bluetooth on my phone, restart Mr12volt, manually connect her phone to Bluetooth and then select carplay. I have to do the same process for connecting to my phone again. She want to try wired to see if it is easier but I haven't had time to pull apart the car and add a USB cable yet.
#429
Regarding us wired connection, every mr12volt comes with a USB cable. Just plug in there. No need to create something new.
Modernize your P-Car w/ Mr12Volt. Apple Carplay and Android Auto with superior audio quality, features, and support. Reach out for specials! Torque.Acs@gmail.com or Roman (267) 317-8229
Our website is now LIVE! please visit us at www.ACSByRoman.com
FREE INSTALL KIT AND CAR CHARGER WHILE SUPPLIES LAST!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
The following 2 users liked this post by Roman ACS:
Mirrorslap (09-09-2024),
World Player (10-09-2024)
#430
I am unable to get phone call audio through car speakers when connected with Android Auto.
Setup:
1. mr12volt has latest firmware.
2. My phone Google Pixel 8 Pro is paired over bluetooth with PCM.
3. Phone is also paired over bluetooth with mr12volt.
Issue:
While using Android Auto, whether a call is made from the phone, touchscreen or steering wheel controls, there is no audio from the car's speakers.
Setup:
Issue:
a. Phone shows active bluetooth connection to mr12volt (screenshot attached).
b. On the phone, tapping the audio button on the call screen to switch audio from mr12volt to PCM, fixes the issue, meaning the call audio can be heard from the car's speakers.
c. Incoming calls are working fine when using Android Auto. There hasn't been an instance where I had to switch audio output.
The (b) isn't ideal as outgoing calls will always require to switch audio output from mr12volt to PCM. I have tried to reset mr12volt reboot the phone, re-paired bluetooth connection with mr12volt and PCM, but nothing helped. Anyone else seeing this issue?b. On the phone, tapping the audio button on the call screen to switch audio from mr12volt to PCM, fixes the issue, meaning the call audio can be heard from the car's speakers.
#431
I've installed the Mr 12 Volt module to my 991.1 PCM 3.1 a few weeks ago since we were going on a roadtrip to Italy.
The Carplay functionality works seemless and boots automatically at start-up. The only issue I have is dat the bottom of the screen seems a bit wobbly every once in a while. It doesn't matter if the connection with Mr. 12 Volt is wired or wireless. Has anybody else run into this issue?
#432
Setup:
Issue:
Setup:
Issue:
#433
#434
#435
I tried these steps -
1. Unpaired PCM and mr12volt from the phone. Removed the phone from PCM as well as P2000>Bluetooth.
2. Restarted the phone and P2000 from the factory menu. Turned off ignition and then turned it back on.
3. Paired the phone to mr12volt.
4. Outgoing and incoming phone calls work through the car speakers. SUCCESS. Steering buttons do not work. FAIL.
5. Paired phone to PCM.
6. Outgoing calls have no sound from the car speakers. FAIL . Incoming phone calls work through the car speakers. SUCCESS. Steering buttons work. SUCCESS. AndroidAuto shows call progress on screen. SUCCESS
7. During #6, if I switch the bluetooth device on the phone from mr12volt to PCM, I can get the phone call sound from the car speakers.
