Door lock actuator replacement
If it's truly non-serviceable, that really sucks.
Would this simply mean the lock actuator just does have enough juice to pull the Bowden cable? I tried to lube the lock area to no avail, did feel kinda stiff though (the lock)
The front passenger door handle just came off in my hand while opening.
And the fuel door does not open - even with the inside pull cord. Coaxed it open with plastic tool to refuel.
Parts on order using VIN - hope it comes in the correct color.
____________________________
https://rennlist.com/forums/cayenne-...meet-otis.html
1) remove door panel and disconnect a few electrical connections (plenty of youtube videos showing how to do this)
2) lower the window about 4 inches, and then remove a couple grommets that cover a hole allowing access to the window regulator bolts. Loosen two bolts with small heads (they spin counter clockwise as the install from the opposite site)
3) slide window to the top and tape in place
4) remove the "inner" door panel. With the regulator lowered you can untuck the upper portion to get it all out of the way, but still connected.
5) remove the outer door lock assembly as the shaft attaches to the lock actuator, simply loosen screw and push and the outer lock becomes "un-hinged"
6) loosen two screws holding actuator in place, disconnect the electrical connection, and the bowden cables, and attach to new lock actuator. One cable is routed to the outer door handle, and the other is routed to the inner door handle.
Install is pretty much the reverse......
If I need to remove those two blind screws on the inside reverse at the top I will but I would be very concerned about getting them relocated on the install.
Can some one correct me or confirm?
TY!!! I gotta do BOTH rear doors!
