Hood sound deadening pad on 2011 Cayenne Turbo?
Received 1,148 Likes
I guess we'll hear.. I'd suggest you add coolant and oil temperature to the mulfi-function-display, I suspect that readout is more accurate than the buffered analog readouts.
Thank you. I found it on sonnen porsche for $103 before tax and shipping. I was just curious because it is a fairly large piece and I imagine sonnen would change a minimum of $30. I found the ebay listing from cardid. Did yours a genuine porsche did it have a Porsche sticker on it?
Chaos (10-17-2020)
The label was covered in packing tape, but does list the part number noted and the item description is in german......good enough for me ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
@ deilenberger I'll do as you said and keep an eye on temps. Being Seattle based might help compared to say AZ.
So a few data points here after a 30 min drive @ 75 degrees using the digital oil/water temp gauge displays o monitor temperatures.
-warmed up and driving 50 mph: water temp always at 201, oil between 203-210, up a hill it crept to 215.
-sport mode and spirited driving: water temp always at 201, oil temps lowered to a low of 197.
-idling in my driveway for 5 minutes after the drive: water temp always 201, and oil steady at 215.
Appear normal?
Appear normal?
Appear normal?
Appear normal?
Water temp staying steady - I kind of wonder if they're buffering that like they do the analog gauge - since the temperature is electronically controlled to aid in running the engine at the most efficient temperature for the conditions.
Dunno - next time I'm out in mine, I'll put those up instead of the compass and something else. Only thing is that might be a few days - weather looks to be top-down weather, so the Boxster gets used mostly. None of those temperatures are scary to me. 215 oil is good for burning the moisture out of the oil.
clorigo (10-21-2020)
Appear normal?
Appear normal?
If this insulation quiets the stupid check valve clicking, I'll install also.
On another note, we can post this thread anytime a newbie comes on and says, "My engine is making a strange noise"
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Interested to hear feedback from others once they get theirs installed.
It remains odd to me that this is a Porsche part, with a Porsche part number, available at a Porsche dealer, and that installing it could have any ill effects. So far so good here.
I don't notice any difference relating to noise, but the engine bay looks much more tidy to me. I'm not sure why these were omitted in the end.....my Panamera has one, same engine.
