ICarScan X431 Tool Available again.
#332
Received 1,141 Likes
#335
no. Doesn’t show over revs unforntunately. It does just about everything else though. Foxwell makes one that shows over revs and I’ll probably buy that as an addition to the icarscan.
#336
Has anyone had any problems with this changing to a different phone? Just got mine, and will be updating my phone here in a few months...want to make sure it is not locked to one phone (for some reason I feel like I read this at one point)
#338
No - not locked to one phone. Locked to one user though (it's locked to your username/password.) I have the software installed on my phone and on an old Android Verizon tablet. Works fine.
#339
I installed on an ipad. When first attempted the app didn't show up. Then I switched options to include iphone apps and the app showed up. Installed on an ipad and works like a charm.
The software will not allow you to fully install without selecting all your 10 options at once. I guess they changed that from before as other comments said you could.
Kinda hate that it does that as I would prefer the option to select based on cars I want later on.
As for the programming the Xenon light ballast that is a no go. I got a used ballast and there is always an error when attempting to communicate with it.
I was able to communicate with my old ballast in place and this thing just shows how much data the car is putting out. WOAH!!!.
I could actually see that the faulty ballast was working and communicating, but was having one fault with voltage on one circuit/pin which was showing 0 instead of 13V like the other side.
I am pretty impressed with it, have already used it to troubleshoot a Mercedes, and a TPMS light on a buddy's Toyota which isolated it to the one sensor.
I'll keep playing around with it, as I can access historical codes which can help track intermittent issues
#341
If it's not one thing.. anyway I own both.
#343
#344
Originally Posted by sprfrkr
You will need the Durametric Pro (not Enthusiast) to do the air bag system.
#345
Beginning with Durametric version 6, Durametric supports the Coding and Command Console features. These features are included with the Professional kits only.
- The Coding feature provides for the ability to enable or disable predefined features in the car such as airbags, daytime running lights, cruise control, and the rear spoiler where applicable.
The Command Console feature is a means of communicating with the control units using very low-level communications. This feature is very seldom used.
