Cardan Shaft?
Received 1,140 Likes
Dilberto - this is a wonderful "McGuiver".. I really love it. I must be ball-less since I replaced the shaft with a rebuilt when mine failed despite having read your original posting. I think I thought my mechanic would think less of me if I did the Jim'i solution.
Someone should make a very official looking service bulletin for this so the mechanics don't give us the fish-eye when we suggest it. Maybe offer a "kit" along with the bulletin (some precut hose and tie-wraps..)
It's a wonderful thing.
Dilberto - this is a wonderful "McGuiver".. I really love it. I must be ball-less since I replaced the shaft with a rebuilt when mine failed despite having read your original posting. I think I thought my mechanic would think less of me if I did the Jim'i solution. Someone should make a very official looking service bulletin for this so the mechanics don't give us the fish-eye when we suggest it. Maybe offer a "kit" along with the bulletin (some precut hose and tie-wraps..) It's a wonderful thing.
Thanks for the fix option Dilberto. I showed this thread to my indy and he approved. A little over an hour of his labor and $0 in parts, and my 955S is rolling again thump free. I've got 80K miles on the clock and he told me to swing by in 10K and he'll give her a look, but he doesn't expect any issues. He also agreed that heavy gauge zip ties should be more than fine.
I was just about to create a topic about this identical issue before i read this.
What you described is exactly what happens when i let off the gas going a decent speed, except i don't have much of a clunk when accelerating.
My question is, instead of replacing the entire shaft can i just replace the mount you linked in the original post? If so how much labor is generally involved in replacement from an indy shop?
Thanks a ton for this thread!
Someone is selling the Vertex support bearing replacement, which is what I think you're talking about. Here's the thread: https://rennlist.com/forums/porsche-...epair-kit.html
Your indy should be able to put this in in an hour (or more like 15 minutes).
Mine went about 110k. I think that's typical.
icspres, you made a big mistake and asked about it, now yours will fail soon... With that said, mine failed at 65K on a '06CTTS. That just happened this time last year. I think some of the earlier cars that did more miles per year they failed at lower age but higher miles. Many of the reports now from us lower mileage vehicles they are failing at lower mileage but with a few years on our cars. Mine went fairly suddenly. I do have a lift in my shop out back and probably looked at my center support bearing at least monthly and it had looked good up to the time when I was coming from a stop on my way home from work and accelerated moderately and thump, thump, thump. Drove it very easily on acceleration and I made it home.
I think failure is more predictable than we give credit. The part that fails is the rubber bushing that surrounds the bearing. If it is beginning to crack and or dry rot then replace it. This said it does require climbing beneath the car and inspecting the bearing periodically.
Mine was replaced at 105k after I noticed cracks in the rubber. Still hadn't failed. Using vertex now. Price was crazy, but...
