Thud when accelerating
Old Jun 17, 2012 | 12:54 PM
sooper's Avatar
sooper
Cruisin'
Default Thud when accelerating
Hi, I dont know if this is normal. Have a 2008 cayenne v6 with 26t KM (A/T trans) on the clock. I notice that on low speeds when i press down on the gas there is s thudding sound which seems to come somewhere from the driveshaft. It is not bothersome but sometimes when my foot is heavy I feel the thud. The car has low milage so I dont know if some support parts have worn down or is this normal for this car. Thanks in advance.
Old Jun 17, 2012 | 02:16 PM
deilenberger's Avatar
deilenberger
search "Driveshaft" and "Cardan Shaft"
Old Jun 17, 2012 | 07:37 PM
mikew968's Avatar
mikew968
center support bearing on the drive shaft
Old Jun 18, 2012 | 05:34 AM
bigbuzuki's Avatar
bigbuzuki
Certainly sounds like the classic cardan shaft issue one reads about, although 28,000 km is unusually low mileage for a worn cardan shaft centre bearing support.
They usually start banging at circa 100,000 km.
Old Jun 18, 2012 | 09:51 AM
touareg's Avatar
touareg
Check your sway bar links in the rear, you could have a snapped one.
Old Jun 20, 2012 | 01:18 PM
sooper's Avatar
sooper
Cruisin'
Thanks for the replies, will the problem be seen when I lift the vehicle?
Old Jun 20, 2012 | 01:32 PM
cordsig79's Avatar
cordsig79
if its the center bearing on the cardan shaft go see other posts but the rubber breaks apart around the bearing.
If it's a thud at shift between gears(up and down) its a tranny issue........
Old Jun 20, 2012 | 01:52 PM
sooper's Avatar
sooper
Cruisin'
Right not based on searches I thing it is not a tranny issue since there is no thud on shifts. Here was something I noticed though, I had an alignment and camber adjustment and it temporarily went away. That mad me think of control arm bushings, though it is only a hunch. Ill try shaking some parts of the underside of the car and see it there is any play. And yes, I have some vibrations at high speeds (120Km/h). I just had my tires balanced twice. No abnormal sound though when speeding. Is there a specific symptom for the center bearing going out?
Old Jun 20, 2012 | 11:04 PM
seankrider's Avatar
seankrider
Cardan Shaft/Center Bearing = midgets banging through the center console... 20 or 30/second. Almost like a violent flat tire.
Transmission "clunk" feels like someone hit you... usually when you accelerate hard. Remedy is probably Valve Body replacement and/or Transmission Control Unit.
Old Jun 21, 2012 | 12:17 AM
SCOTITUDE's Avatar
SCOTITUDE
if its not the cardan shaft bushing, check the rear control arm bushings. when they rip they make a noise when susp changes direction, like accel after reversing. will be a single clunk per direction change.
Old Jun 23, 2012 | 11:26 AM
sooper's Avatar
sooper
Cruisin'
Think this is where I'll dig into first. bushings are cheap to replace and yes, it is a single thud and I get it also on reverse then drive as a single thud like something bumping you from behind. It is quite hard at times to reproduce maybe because the bushings arent that worn out yet. Wish me luck, I hate to see the transmission go down at only 26t Kms.
Old Jun 23, 2012 | 04:20 PM
SCOTITUDE's Avatar
SCOTITUDE
i need to correct myself, its the bushings on the front lower control arms, usually the rear one.
Old Oct 4, 2012 | 08:44 PM
endless_corners's Avatar
endless_corners
I have this clunk/thump when first starting or changing direction from forward-->reverse (and vice versa). I have just replaced the drive shaft. How do I check the bushings. Is it possible to visually inspect bushings in the control arms? I dont have a lift or jack anymore since I moved into a townhouse (had to get rid of a bunch of tools unfortunately).
