Cayenne Engine Replacement
Old 12-24-2012, 05:36 PM
  #121
Cole
Cole's Avatar
You can buy a automotive stethoscope for about $15-20 at the local hardware store. You would be amazed at what you can hear going on inside the engine.
All the "noise" goes away when you touch the stethoscope to the engine block and all you hear is that specific location. Obviously be VERY careful around moving parts like the fan and belts!!! You should be able to touch most of the rest of the cyls and valve cover locations and listen to what is going on.
Old 12-24-2012, 05:41 PM
  #122
meatpie
6th Gear
meatpie's Avatar
I wouldn't no what I'm looking for in all honesty mate I'm not very clued up on the cayenne. I live on a small island with 1 dealer so I put my faith with them and they didn't no what it was. shocking if you ask me
I will record the sound and post it here when I get the stupid thing started.
Old 10-08-2013, 09:11 AM
  #123
ventuje
ventuje's Avatar
Resurrecting this thread, last week my 2004 C4S with 82,000 engine failed. Always dealer maintained at proper intervals. About 8 months out of extended warranty. Was coming home one night, started to stutter, then just quit like the engine fell out ! No idiot lights or anything. Stealer wants 30k to replace engine! Bore-scope revealed no piston in cylinder 3 and visible crack, coolant and metal in oil. Any ideas on best approach to get Porsche NA to own up and do the right thing? If not, any idea where/how to get rebuilt short or long block?
Thanks for the advice
Old 10-08-2013, 09:33 AM
  #124
jumper5836
jumper5836's Avatar
Do you have a Cayenne or a 996? There should be plenty of Cayenne V8 engine out there from accidents in scrap/part yards. You could probably find a running used Cayenne one for 10k and do a engine transplant.
Old 10-09-2013, 09:39 AM
  #125
ventuje
ventuje's Avatar
It's a Cayenne V8. Did they fix the problem in 2008 4.8? If so think I could transplant one of those without too much difficulty?
Old 10-09-2013, 10:24 AM
  #126
jumper5836
jumper5836's Avatar
I'd find a like for like engine. Switching a new different engine you'd end up with a ton of other issues and probably emissions problems not sure a dfi engine could even work in it. I have not heard of any engine problem with the Cayenne that needed to be fixed. Only hear about coolant pipe problems.
Old 10-09-2013, 10:29 AM
  #127
mudman2
Moderator !x4
mudman2's Avatar
Theres nothing wrong with the 04 V8, I would stick with like for like, you might end up replacing much more than the engine to get all the control modules to match before it will run and they ain't cheap
Old 10-09-2013, 11:27 AM
  #128
ventuje
ventuje's Avatar
Theres nothing wrong with the 04 V8,....
Mike
So my cracked cylinder indicates nothing wrong? Along with the numerous other failures in this thread? How can you say that?
Old 10-09-2013, 11:29 AM
  #129
mudman2
Moderator !x4
mudman2's Avatar
In general I meant, its mostly a bullet proof motor, who knows what happened to yours thru the years but its an exception rather than the rule
Old 10-09-2013, 11:37 AM
  #130
jumper5836
jumper5836's Avatar
I'll add probably as result of running that crap 0w-40 stuff
Old 10-09-2013, 11:39 AM
  #131
mcbit
mcbit's Avatar
I have to agree with the advice already given, there are plenty of 4.5 V8s around with plenty of miles on them. The problems with 955 V8 Cayennes are generally with the ancillaries and not with the engines themselves. I would quite happily go out tomorrow and buy another one.
Old 10-09-2013, 12:18 PM
  #132
ventuje
ventuje's Avatar
Wish I had your optimism, but I can't get into another Porsche at this time - soured. Any suggestions what to do with this vehicle that needs an engine? try to sell as is, find used (where), any rebuilts out there?
Old 10-09-2013, 02:22 PM
  #133
jumper5836
jumper5836's Avatar
Best to search local part/wreckers yards or ebay. I found this one here. No affiliation. http://www.ladismantler.com/parts/77...4-5-V8-Engine-
Old 10-09-2013, 07:36 PM
  #134
cordsig79
cordsig79's Avatar
Burn it, kill it with fire......
Drop it off at a boat ramp and let her roll......
Or have a 928 guy tell you how to hack in an American crate motor.....
Old 10-09-2013, 09:46 PM
  #135
hahnmgh63
hahnmgh63's Avatar
You don't post your location but there are a couple on Ebay. Also a large wrecking yard usually will have access to a National Database of wreckers and may be able to help you with a search.
Quick Reply: Cayenne Engine Replacement
