What Did You Do To (or With) Your Cayenne Today ?
#61
Replaced the air/oil seperator diaphragm that had gone bad. That black cap was on far more than I anticipated. No more Spy Hunter smoke screen or CEL on startup!
Also ordered a windshield washer pump & a Turbo instrument cluster from an 08. Gonna see if I can make it work on my 08 GTS!
#64
All new front suspension, new headlight wiring harness, sway bar end links, and diverter valves. Just waiting on the final pieces tomorrow (sway bar end links).
#66
#67
I know a ton of people have done this so thought I would have a go.
Taking the stock Cayenne S Exhaust and doing a muffler bypass. This is the sound before adding the tubing which has a link below
Before
Then took the tips off and pushed this tubing through after cutting the small bypass valve out
and now sounds like a turbo![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Before
#68
Wash, clay bar, scratch x, wax. Cursed p.o. for using wrong colour of touch up paint. Ordered correct paint.
Checked if stealership had serviced it prior to sale as described. Cursed at lying salesman and ordered oil filter for fitting Wednesday.
Checked codes confirmed thermostat open or being bypassed. Ordered thermostat and socket for fitting Wednesday. Cleared codes.
Cycled vvt solenoids, checked plugs, air filters, cabin filter, drains, brake fluid, coolant mix, cardan bush, lubed sticking passenger mirror motor, stopped heat shield rattle, checked droplinks and suspension bushes, checked engine brace bush, changed opening height on the boot/trunk.
Tried to download Foxwell Porsche software for new n520 but don’t have the right card reader.
Loved every single second of it.
#69
Before
https://youtu.be/0-_pbAY4uAQ
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
https://youtu.be/k2GSrjCpcGk
Before
#71
As there was a "with" your cayenne.....Dune running
https://www.facebook.com/Cayennegtsoffroad/videos/509356862898621/
#73
#74
