Vcds How to
#46
#47
Hi Bob
I think I may have confused you completely!
I’ll have another go at explaining.
The last pic is the VCDS cable. It’s not the Cayenne.
the pins are numbered the same no matter which end we are talking about. 1 male (in the VCDS cable) goes to 1 female (in the car).
So, we are simply connecting a cable (VCDS) to the car via an extension lead (or splitter. Serves the same purpose).
So, without us altering anything, pin 1 from the cable goes to 1 on the extension and 1 on the car. 2 to 2 to 2 etc etc all the way to 16.
You need to change ONE thing in the extension.
Find the wire that extends pin 15. Cut it.
find the wire that extends 3. Cut that.
now, join them together. 15 to 3. And 3 to 15.
One of those will make it work, one is completely useless but it may make it easier!
That is it. All you need to do.
ill take another photo tomorrow with the cable laid out.
#48
[QUOTE=Stringbag;16459221]Hi Bob
ill take another photo tomorrow with the cable laid out.[/QUOTE
Hi....I have followed your last post with some results...still can't read the engine and transmission data....its about the same as my original VCDS cable?
Not sure what i'm doing wrong...guess a photo of your cable would be a help..
Thanks again for your patience's...Bob.
#49
[QUOTE=Whimpy;16463555]
So which modules did you get?
Now try connecting the VCDS cable straight to the car with no extension/splitter at all. (You should get the DME and transmission that way, but no others).
thats blocks 1 and 2 to save you some time.
Hi Bob
#52
I just had an interesting thing happen. I ordered a vcds from Ross-tech and they just got the payment so when they checked the order and saw I have a Porsche they sent an email that since they don't support Porsche they would cancel the order and refund my payment. I called and talked to Helen, who was as nice as could be, and she informed me she had to do this as policy. If I go with it it anyway I just don't get tech support. I asked her to go ahead with it anyway and I'll get support here if needed (or one of their tech's who owns a Porsche might answer an email). Did anyone else with a vcds go through this?
#53
Stringbag, I have a question. I just got my VCDS and modified a splitter OBDII cable with pins 3 & 15 spliced together as noted above. I cannot get auto scan to work. I believe the message it gives is not supported by module. I'll get a screenshot later. Any idea what may be wrong? Also, do you know where I can find the coding values for various modules? VCDS does not give much support from what I've seen so far.
Tom
Tom
#54
Hi
It won’t auto detect - the Car is too old. You have to select Touareg (or cayenne if you have enabled it).
see here
https://www.ross-tech.com/vcds/tour/autoscan.php
To personalise the list of vehicles to Your installation of VCDS- is add Porsche cayenne (or Lamborghini, or Bentley etc etc) follow this link as only VW or Audi cars are enabled on the list out of the box.
https://forums.ross-tech.com/showthr...un-and-profit!
see here
#56
Auto scan successful on '06 CS Ti
I followed Stringbag's advice and auto-scan was successful. Below is the log.
Tuesday,26,May,2020,15:49:04:36392
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WP1AB29Pxxxxxxxxx License Plate: HTM7049
Mileage: 304100km-188958mi Repair Order:
Chassis Type: 9P (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WP1AB29P06LA70257 Mileage: 304100km-188958miles
Address 01: Engine Labels: None
Part No SW: 8SL VAS N80 000 HW: Hardware No
Component: 0041800144HH8SLVG 80168
Coding: 0000133
Shop #: WSC 128452 000 00000
VCID: 074B9E4F3335D6B3121-5184
No fault code found.
Readiness: 0000 1100
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 CM
Component: AL 750 6A 0908
Coding: 0012328
VCID: 7BA3F2BF7FFD8253069-5184
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 C HW: 5WK 485 06
Component: Kessy 6840
Revision: 68406418 Serial number: VWZ3Z0F5534747
Coding: 0524449
Shop #: WSC 31414 790 00001
VCID: 290FF8F7C5B1C0C3245-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L5 907 040 BM
Component: Klima - SG R/L 4323
Coding: 0000030
VCID: 7BA3F2BF7FAD8253069-802E
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L5 937 049 D
Component: 3002
Coding: 0102398
VCID: 3C2131A33A23456B4F3-8068
1 Fault Found:
00907 - Intervention load Management
000 - -
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 26 Airbag 8.4E++H01 0573
Revision: BB38727 Serial number: 0009633:
Coding: 0012854
VCID: 2809FDF3DEBBF9CB3BB-807C
Subsystem 1 - Part No: 659 256 501
Component: BF-Gewichtsens.
Address 16: Steering wheel Labels: None
Part No: 7L5 953 549 D
Component: Lenksäulenmodul 1701
Coding: 0001311
VCID: 3FDB46AF2B355E736A1-806A
Address 17: Instruments Labels: None
Part No: 7L5 920 970 K
Component: KOMBIINSTRUMENT RB8 3710
Coding: 0015204
VCID: 3E253BAB2C5F577B617-5184
Address 19: CAN Gateway Labels: None
Part No: 7L5 907 530 A
Component: Gateway CAN/CAN E1 1200
Serial number: ÿÿÿÿÿÿÿÿÿÿ
VCID: 313F1097ED61B803EC5-8064
1 Fault Found:
15504 - Unknown Error Code
004 - No Signal/Communication - Intermittent
Address 22: AWD Labels: None
Part No: 0AD 927 755 AM
Component: TRANSFERCASE 1110
Shop #: WSC 00000 000 00000
VCID: 0655934B340FCFBB697-5160
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABEE8F4385A633621-8022
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 H
Component: XC HSG 0400
Coding: 0001045
Shop #: WSC 01622 552 00000
VCID: 41DF40575DA128831C5-4B1E
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
Subsystem 5 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L5 951 171
Component: Innenraumsensor 0020
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 56: Radio Labels: None
VCID: 55F78407BD49B42350D-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
VCID: 38292DB30E1B694BABB-806C
End----------(Elapsed Time: 08:11, VBatt start/end: 13.9V/13.9V)-----------
www.Ross-Tech.com
Coding: 0000133
Coding: 0012328
Coding: 0524449
Component: ELV XXXX
1 Fault Found:
00955 - Key 1
Coding: 0000030
1 Fault Found:
Component: 3002
Coding: 0102398
1 Fault Found:
000 - -
Coding: 0012854
Coding: 0001311
Coding: 0015204
1 Fault Found:
Coding: 0001045
1 Fault Found:
000 - -
No Faults Found
Coding: 0000002
Now to just figure out some coding for things like the supplemental air pumps.
www.Ross-Tech.com
Coding: 0000133
Coding: 0012328
Coding: 0524449
Component: ELV XXXX
1 Fault Found:
00955 - Key 1
Coding: 0000030
1 Fault Found:
Component: 3002
Coding: 0102398
1 Fault Found:
000 - -
Coding: 0012854
Coding: 0001311
Coding: 0015204
1 Fault Found:
Coding: 0001045
1 Fault Found:
000 - -
No Faults Found
Coding: 0000002
www.Ross-Tech.com
Coding: 0000133
Coding: 0012328
Coding: 0524449
Component: ELV XXXX
1 Fault Found:
00955 - Key 1
Coding: 0000030
1 Fault Found:
Component: 3002
Coding: 0102398
1 Fault Found:
000 - -
Coding: 0012854
Coding: 0001311
Coding: 0015204
1 Fault Found:
Coding: 0001045
1 Fault Found:
000 - -
No Faults Found
Coding: 0000002
#57
I was just looking through the auto scan file and it has 3 Cayennes listed and 2 Panameras. I didn't look at it before doing the scan, but would the scan update it with info it finds? The Cayennes are listed as ;9P, ;92, ;A2. No years listed.
#58
Excellent! Success.
With regards the models, maybe. Try it! No harm done. Or just look through the differences and take a pragmatic view.
I made a bespoke ‘my cayenne’ file with just the modules fitted to my car. Saves time as it searches three times before it skips to the next one. I don’t have a pano roof for example, or a towbar, so no point scanning for those modules.
You can add and remove the address labels as you see fit.
#60
Hi StringBag, I tried to follow your instructions, connecting #15 to #3. I purchased a standard OBD exrtension cable. After jumpering the two terminals, i connected it to the Cayenne and ran VCDS. I only got two modules. So i might be doing something wrong. Please see attached pic. Thanks so much for your advice.
Your advice would be very helpful.
