The Bad News piles up about the new Turbo
#211
Ohhh! I stand corrected... Look at what Walter Rohlr is taking to compete at the NBR 24 hr enduro next year according to this mob... a 9A1 powered pdk TT??? Not!!!
http://www.crash.net/world+rally/new...rburgring.html
Case closed for me on new motor vs old... Pay peanuts, get peanuts... Make mine a M64 Metzger thanx!![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I wonder if the 9A1 can even idle in the driveway for 24 hours???
#213
As far as reliability is concerned I think that it is a bonus that the new engine achieves these results at lower boost (made possible by a higher compression ratio and higher red line) as well as the 40% decrease in overall engine parts. These changes bode well for the robustness and reliability of the design. Those who argue that the new engine is unproven from the standpoint of upgradability miss the point. The stock car will outperform many modded 997.1 turbos anyway at lower overall cost, so large horsepower improvements, even if they could not be achieved, may not even be necessary.
#214
Yes we know about the drawbacks of DI. In the NA motor there has been tail pipe soot accumulation, excessive oil consumption and (probably unrelated) HPFP failures. These are all known issue with the first iteration of this engine.
#215
So Boo, when is your new TT arriving? Maybe you can do the 24hr idle test for us all? I'll gladly send you a cheque for the fuel if you like...
#216
what is this, the second grade? LTC, can i used the restroom please?
boo, when you find yourself in a hole, the first thing you should do is stop digging. put down the shovel, man.
for my argumentum ad hominem i present that you should send VR a note to get some help on in the avatar category.
In fact why are you even wasting time posting on RL at all when, instead, you could be rioting in the streets of Copenhagen with your fellow anarchists?
#217
The only single feature of the the new turbo motor which is "new" is the Dfi. The new engine's "magic" is the combination of Dfi with 3.8litre, higher compression and VTG turbos
Last year Schmirler built Mezger high compression 4.1litre turbo engines with VTG which make 700hp at 1 bar with Euro 5 emissions, the Mezger engine can do all the Dfi's tricks and run Porsche reliability with 200hp more.
We know the new motor needs rods and pistons to survive at even 550hp - just how structurally weak is the architecture of the new casing ?
Did anyone ever find out why Dfi was not adapted to the Mezger ? Can't be done ? Of course it can..... it wasn't done because of money, Porsche wanted to make even more profit out of the already ludicrously profitable 911 turbo.
IMO The turbo should have been moved way upmarket to be with the big Lambos and Ferraris, had a 650PS with 800NM @ 2500rpm Dfi high CR 4.0 litre VTG Mezger with beefed up PDK - it would then represent the true Porsche flagship and its performance would dwarf ALL opposition.....
#218
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#219
Seriously, one of the reasons you've dug yourself into such a rhetorical hole is because you've tried to make this issue a referendum about me. The sooner you return to debating the facts of the matter, the more credibility you will have. If you like to see how a mature adult approaches this topic take a look at the posts above by eclou and TB993tt and some others, ltc excluded.
Now maybe you could comment on the post made earlier today where the new turbo did 0 - 60 in 3 seconds flat. That's almost a full second faster than the outgoing model.
I know that something like this is painful for you to acknowledge and that it is much easier for you divert people's attention by focusing on me personally.
You can keep it up, if you wish, but (as before) it will get you absolutely nowhere.
#220
Super Moderator
Needs More Cowbell
Needs More Cowbell
BTW, if this new version of the Turbo IS in fact the single greatest achievement in the long history of the "911 Turbo" and clearly superior in every facet to any '911 Turbo' that has come before it, exactly when are you going to get yours?
#221
The same day you get your Cayenne, Lewis.
#222
Working out pretty good for you?
#223
I'd say 0 to anything is totally irrelevant in the real world. You never ever do full-bore launches on public roads. At least I haven't in 5 years of various 997 ownership. This is why I always use 100-200kph as the best real world indication of how fast a car is, at least in a straight line.
![](http://i238.photobucket.com/albums/ff117/Alex911TT/cars/porsche/webboards/Porsche_results.gif)
Most (650 kits) are running the 1/8th and 1/4 mile the same as the new stock turbo.Sending the car out for that kind of work is maybe 20k?
From reading thru alot of post some claim that the 650-750hp kits even on the 996TT and 997TT-1 horsepower or is it torque curve comes in milder because of pressure on the rods and thats why tuners get high horsepower number but the cars don't ET anywhere near what the horsepower figures are.Also clutches on the manual don't hold up with higher horsepower unless you run a good aftermarket clutch, the new PDK will be tested hopefully it doesn't run into problems like the GTR.Nissan pushed it with launch control and looks like Porsche is going to have one that finishes it! As if a car took full advantage thruout the range of 650 to 700hp the 1/4mile numbers would be more like high 9's and not high 10's to low 11's in the 1/4.There are a few that are running that and those cars are making true figures.
The overall new 997TT is now made a good overall car even more so for drag racing.Looks like only cars quicker are the 700+hp kits as the 650hp kits look to run very close to the new turbo with 1/4mile figures.Its not how many horse the car makes it where it makes the horsepower and how well it can deliver it,but like you say have to see how well it holds up before sinking money into going out for a new car.
http://www.dragtimes.com/compare2.ph...ame=Compare%21
Alot know the sledge hammer which really stands out but the rest are about the same or slower than the new car
I would say the real world is both road racing and drag racing as in any real straight line racing there is only drag racing.
Nice chart on the times for the cars.
#224
Looks like that, no matter what the maximum horsepower output of these modded 997.1s are, they generally do not perform at the level as the STOCK 997.2 turbo.
And performance is the bottom line.
Your only hope at this point is to wish that these stock engines grenade so you can post some dramatic pics of dissasembled engines and say "I told you so."
Very strange that Porche puts out a whole new car and die hard self styled Porsche "enthusiasts" are praying for it to fail.
#225
Looks like modified 997TT-2 are starting now and the cars will be getting faster.
10 second 1/4 miles and sub 3second 0-60's would like to see how this setup runs.
https://rennlist.com/forums/997-turb...7-2-turbo.html
