OFFICIAL DSC SPORT DISCUSSION FORUM
#421
The financial problem is that the cost delta between 996 and 997 is starting to come down. You would have to have a very special 996 to make a good case for doing this, otherwise it might be cheaper to buy a PASM 997 and retrofit your controller OR a non-pasm 997 and retrofit a B8 damptronic system and your controller.
#422
#423
Subscribed
Installing the DSC unit in my 991RS tomorrow and will be taking it to SIlverstone on Sunday. Will report back. Have not done SS in the RS yet so will not have direct comparison.
#424
Originally Posted by Mika911
Subscribed
Since it’s a 5 min install maybe do the morning sessions without it and then switch out to the DSC?
I just picked mine up excited to try it out in 2018. Spring can’t come soone enough.
#425
Got a good drive in the car, first on the fabulous (not) M25 around London on which the car drove clearly a lot smoother with DSC. On track however I cannot say I noticed a difference in the way the car felt. Though I am not familiar with Silverstone, I have done about 5000 miles on track in the RS so know the car very well. I also did some pax laps with a friend in a non DSC RS and it felt very similar. The main reason I got the DSC was to hopefully reduce the cording on the outside rear. However, today the tyre went from no cording to lots of 1cm chucks to the canvas in one fast session. I presume this is due to the characteristics of the track, but I was a bit shocked about the speed at which it happened (despite using the DSC). Tyres had done two previous track days.
Next drive will be 2.5d Portimao in March, so by then I will need to redo the geo (currently it is quite aggressive which does not seem to work well with the RS). Look forward to then do some more testing of the DSC.
#426
Should really have done that, but decided not to as the guy installing the unit initially had some issues with warning messages coming up. Since these were cleared I did not want to tinker with it.
https://www.pistonheads.com/gassing/topic.asp?t=1546871
Portimao is a great circuit, I went there in September and also Estoril and Jerez.
#427
You may know him but if not you might reach out to APOLO1 on PH. He has a 991 GT3RS (amongst most other really nice modern Porsches), does many Silverstone days with Goldtrack and pays attention to set up. He posted initial impressions on the thread linked below and offered to share his set up.
#428
#429
Mika911,
How old is your DSC? Who installed it? Email me your mapping file, I'd be glad to have a look.
Thank you for your feedback thus far.
Regards,
Tom
tchan@tpcracing.com
Regards,
Tom
tchan@tpcracing.com
#430
A couple of questions:
1) Does a 997.2 dsc module for a turbo work in a GT3? I would assume there is a different spring rate therefore a different firmware / map. I’m considering buying a used one.
2) How does the 997.2 GT3 w/DSC compare with a GT4 ride?
The reason I ask is because I loved the suspension in the GT4 and I’d like a way to get more of a ride like that on bumpy back roads.
#431
^^^ biggest difference is that the GT4 can adjust mid stroke where the 997 platform cannot. lots of other changes but that's a whopper in the 'ride' dept
#432
DSC versus Moton DA
I have been following the success of the DSC module with great interest since the introduction in 2015. I would like to re-ask a question that was addressed in POST #33, way back at the beginning: Does anyone have some real world comparisons between running the DSC with OEM PASM shocks, versus installing a Moton (or other good quality) double adjustable remote cannister shock? I have a nicely set up 2007 GT3, double adjustable Motons:
Rear:
Front canister and adjuster:
I blew out a seal on one, so I pulled them off and sent out for rebuild and dyno. I stuck the OEM PASM shocks back in so the car could still drive, and recently got the Moton's back. While the OEM shocks are already back in there, it got me thinking about what would be faster, OEM's on DSC, or putting the Motons back in. I am an intermediate DE driver, not afraid to use the curbs, and the car, while it has a license plate, is basically a dedicated track car. For driving style, typical 2:25 lap at COTA:
Any updates or thoughts about DSC versus manual adjustables? Thanks!
Rear:
#433
Do you offer an ajustable camber plate option when buying tractive DDA complete suspension kit for the front ones?
I ask just cause I saw you recommend -2.5° for front camber.
#435
