Steering wheel trim removal
https://rennlist.com/forums/997-gt2-...ing-wheel.html
here you go bud. This is a decent read - Hoping it helps
Thanks for the response. However I'm looking for any info on how to get the steering wheel center trim piece off of a .2 RS. Anyone have an idea? It doesnt seem to be screwed on anyplace. Maybe its glued and not ment to be removed? Id like to paint it to match the exterior color.
Ask the guy that started these threads:
https://rennlist.com/forums/987-foru...moval-how.html
https://rennlist.com/forums/987-foru...rim-piece.html
He's doing the same thing
I took mine off several weeks ago for a steering wheel re-wrap and swap to a multi-function center piece. No screws, no glue -- just plastic anchor rivets. Use plastic trim removal tools and a lot of elbow grease. It requires a lot of effort to pry the center piece off -- major PITA. Here's a DIY link from another forum. There is a post on the actual removal process with pics. Hope this helps.
http://www.6speedonline.com/forums/9...e-997-2-a.html
Perfect. Thank you!
Thanks a bunch guys. As soon as I knew what to look for (based on all your help), it popped right off. I used the wheel as a leverage point and an interior trim pry tool and it was a piece of cake.
Great source for paint to match oem colors. I bought both their spray paint and touchup products. perfect match. I'll use plastic primer, their matched spray paint in black grey and a satin clearcoat to finish. I've already done my door spears and mirror triangle bits. Worked great.
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
