Gen 2 Airbag Removal - HOW?
Gents,
I want to remove my steering wheel so that I can send it off for re-trimming. I mistakenly assumed it would be just like the Gen 1 cars which had (well my old one did), a hole on on the underside of the wheel which you could insert a screwdriver into and so release the airbag. This would then allow access to the bolt retaining the wheel.
My Gen 2 wheel (pic below), doesn't have the same hole which is used to release the airbag. Can anyone assist?
Thanks,
Thanks,
Actually, you have the right idea. There is a hole to push up through underneath, but it is covered with a thin layer of upholstery. You have to break through it. You'll feel the small indent/blister where the hole is. Punch through it
Admin
Thanks for the link....I didn't actually go through the procedure noted before disconnecting the battery. No key in the ignition, I disconnected the negative terminal and waited about 5 mins before removing the airbag and wheel from the car. I'll now leave the battery disconnected for the week or so it'll take to get the wheel re-trimmed.
Should that be ok?
Should that be ok?
You should be OK. Worst case scenario is you go to the dealer to have the CEL reset or buy a durametric cable (what I did). Post pictures when you get the wheel re-trimmed. What are you having done?
btw, the silver belts in your silver spyder look good
What a hell of a job that was..!!!
I have a question about the "T" piece of the wheel. What do you think about having it painted body colour? I'll start a new thread to ask opinions
