997 GT2/GT3 Forum 2005-2012
The Center-Lock recall...
Old 07-16-2011, 12:51 AM
  #106
10 GT3
10 GT3's Avatar
I had it done on my car and got the full instructions on how it works. You bring in your can and they check if the nuts break loose below the torque spec. If they do, they have to inspect the wheels and hubs for damage. If any parts show damage from a loose nut, they replace the damaged parts. If the nuts are marked 500nm, they get automatically replaced with the ones without the load marking. The ONLY reason why the nuts are being replaced is a liability issue if you go to someplace other than a Porsche dealer and the torque the wheels to the rating on the nuts, which are now marked with the incorrect load rating. There is actually no change. And if you are like me where you are on your 3rd set of tires and 2nd set of brakes having your wheels taken on an off frequently, they are torqued regularly to the proper spec and there is not an issue. The only car they saw that had a wheel nut below with a torque issue was an early delivery car that hardly ever gets driven and was never tracked. It never came in for service, prior to the recall. One of the nuts came broke loose with almost no effort when they checked it. It still didn't show any damage on the hubs or wheels.
As far as a spare set of nuts goes, I believe you need to take that up with the parts department where you bought them.
Old 07-16-2011, 03:18 PM
  #107
afridi
afridi's Avatar
Originally Posted by KBS911
OK, this is interesting. How many of you have bought a second set of C/L's. I did. Called the dealer and asked if they could be replaced since they were purchased through the dealer network. Part manager's first response was that he didn't think so because the replacement had to be tied to a VIN on a car for warranty replacement.
After I asked him if Porsche was prepared to accept the liability for use of and OEM part sold by a dealer he quickly saw my point and stated that he would have to check, since this is all new.
My thought is that if you buy a Porsche OEM part of any kind that is subject to a recall that you should get a replacement.
Just got the notice today. My documentation mentioned that if you have purchased additional centelocks then they will also be replaced by Porsche.
Old 07-16-2011, 06:04 PM
  #108
MJones
MJones's Avatar
Got my nut's changed....
No muss, no fuss
Old 07-16-2011, 06:31 PM
  #109
10 GT3
10 GT3's Avatar
Got my documentation today. There is a fold-out for the updated centerlock procedure. It states even the GTS on the front, so it looks like GTS was also part of the recall.
Old 07-16-2011, 06:54 PM
  #110
911SLOW
Admin
911SLOW's Avatar
Technical Information
Service
73/10 EN 4405
Central wheel lock: Additional instructions for driving on race circuits (73/10)
Vehicle Type: 911 Turbo (997)/911 Turbo S (997)
911 GT3 (997)/911 GT3 RS (997)/911 GT2 RS (997)
Model Year: As of 2010
Equipment: Central lock (I-no. 422, 430)
Concerns: Vehicles with central lock on wheels
Situation: Additional instructions for the use of the central lock components when driving on race circuits
Before a vehicle with central lock on wheels is driven on race circuits, the central wheel bolts must be
greased as described below and tightened to a higher tightening torque.
Part Nos.: 000.043.020.00 ⇒ Assembly grease Optimoly TA 100g tube
Tools: Socket wrench 9796
Assembly aid 9794 (for vehicles with PCCB – Porsche Ceramic Composite Brake)
Torque wrench Nr.91 Pos.2 (300–800 Nm/222–592 ftlb.)
Action Required: 1 Grease central wheel bolts in accordance with the following overview before driving
the vehicle on race circuits.
To do this, first remove and partly disassemble the central bolts. For details, see ⇒ Workshop
Manual ’440519 Removing and installing wheel with central bolts’.
..."etc
According to the TI above (that is still active btw) titled " Additional instructions for driving on race circuits"..
500Nm is still ok for road driving, so again I am missing the issue that brought Porsche to this situation, and can't understand why some cars show wheel and hub damage..
a. Some cars left the factory with wheels torqued below specs?
b. They found out that 500Nm of torque is not enough for track usage but ok for road driving. Like you can't push the car on public B-roads.
c. all the above
d. we 'll never know
And now you are saying that they torque all cars to 600Nm based on a still unpublished in the PIWIS instruction..
Old 07-16-2011, 07:28 PM
  #111
911SLOW
Admin
911SLOW's Avatar
edit:
just checked the workshop manual and they 've added it:
WM 440519 Removing and installing wheel with central bolt
Tools
Designation Type Number Description
assembly aid Special tool 9794
socket wrench Special tool 9796
Information on central bolts
Information on tools - central bolt system
Only use socket wrench 9796 -1- on the 911 with centre-lock wheel.
Never use socket wrench 9451 -2- , from the Carrera GT.
Reason: The lockable wheel bolt (locking mechanism) will break off because there is no plunger for releasing the lockable wheel bolt.
This means that the wheel will not be secured. This can no longer be detected once the hub cap is fitted!
Only socket wrench 9796 -1- can be used on the 911 with centre-lock wheel!
To avoid any confusion, affix an appropriate sticker to the special tool from the Carrera GT - socket wrench 9451!
Order number for this sticker = 000.721.945.11
Socket wrench for central bolt system
Component overview - central bolt system
Component overview of central bolt system 1 - Hub cap
2 - Wheel bolt with cone ring (not available separately)
3 - Wheel
4 - Lockable wheel bolt/locking mechanism (not available separately)
5 - Wheel hub
6 - Brake disc (grey cast iron or PCCB)
7 - Wheel driver (only available in a set as spare part/5 ea. No. 7)
Wheels with central bolts will be available for the 911 Turbo in the current model year 2009 (from March 2009/as an option, I-no. 422).
The central bolt system comes as standard on the 911 GT3, as of 2010 model. Technically, the central bolt system is the same as that used on the 911 Turbo. But the wheels are different and the colour of the wheel bolts may be different.
Wheels with central bolts -3- are secured with a wheel bolt -2- (wheel bolt with removable cone ring) to the wheel hub -5- . The wheel bolt -2- is made of high-strength aluminium and has a trapezoidal thread (right-hand thread). The same wheel bolt -2- is used for all four wheels.
The lockable wheel bolt -4- is an assembled component (only available complete), which has toothing that engages in the wheel hub -5- on one side and in the wheel bolt -2- on the other side (if activated).
The lockable wheel bolt -4- can be pulled out when the wheel bolt -2- is removed in order to remove it from the wheel hub -5- . For safety reasons, only remove the lockable wheel bolt -4- in order to check it and then re-insert it immediately in the wheel hub -5- .
Check that the lockable wheel bolt -4- is working perfectly before fitting the wheel.
The contact surfaces of the wheel on the brake disc -6- must be clean and free of paint and grease.
The wheel drivers -7- (5 ea.) comprise the driver pin, sleeve and self-locking screw. Only one set (5 ea./for one wheel) is available as a spare part.
Five new wheel drivers -7- (1 set) must be fitted when replacing the brake disc. Tightening torque for the self-locking screws = 6 Nm (4.5 ftlb.).
Removing wheel with central bolt
– Only use the permitted special tool -1- socket wrench 9796 on the 911 with centre-lock wheel!
Important: “Never” use special tool -2- (socket wrench 9451) from the Carrera GT on the 911 with centre-lock wheel.
To avoid confusion, stick an appropriate sticker on socket wrench 9451 (for the Carrera GT)! Order number 000.721.945.11.
Reason: The lockable wheel bolt/locking mechanism will break off because there is no plunger (on the Carrera GT tool) for releasing the lockable wheel bolt.
1. Raise the vehicle only at the jacking points provided. → 4X00IN01 Lifting the vehicle. Alternatively, raise the vehicle (handbrake on) until the wheel you want to work on is up off the ground.
2. Carefully lever the crested hub cap out using a small screwdriver.
To do this, guide the screwdriver deeply into the opening groove and then carefully lift up the cap.
Do not turn the screwdriver to the left or right while doing this!
Stick adhesive tape on the screwdriver if necessary to ensure that the screwdriver does not scratch the surface of the central bolt.
Removing crested hub cap
Information
The lockable wheel bolt is only released when special tool 9796 is fitted as far as it will go onto the wheel bolt (safety lock on the central bolt is pushed back).
The socket locks at this position.
Get a second person to press the brake pedal to prevent the wheel from turning.
When loosening the central bolt, make sure that the tool remains fully engaged and does not slide off even slightly (risk of damage to the lockable wheel bolt/locking mechanism).
A very high torque is required in order to loosen the central bolt. Always turn in the correct direction (anti-clockwise to open the central bolt).
3. Socket wrench 9796 -1- (socket) must be fitted and pressed on as far as it will go. The socket -1- locks at this position.
The lockable wheel bolt is then released.
Positioning tool
If the lockable wheel bolt (locking mechanism) is difficult to move in axial direction (becomes tilted in the wheel bolt toothing/socket cannot be fitted), loosen the locking mechanism using a suitable mandrel (press towards the wheel hub).
To ensure that the socket -1- can then be pulled off the wheel bolt (using an acceptable amount of force), grease the O-ring on the release plunger.
4. Unscrew the wheel bolt you released using special tool socket wrench 9796. Get a second person to press the brake pedal to prevent the wheel from turning.
Opening central bolt (turning anti-clockwise)
When loosening the central bolt, make sure that the tool remains fully engaged and does not slide off even slightly.
5. Unscrew the central bolt and set it down in such a way that the conical area or trapezoidal thread cannot get dirty.
Unscrewing central bolt
6. In the case of vehicles with PCCB (Porsche Ceramic Composite Brake), screw an assembly aid 9794 (hub extension) -1- into the wheel hub before fitting the wheel.
This prevents damage to the brake disc when taking off the wheel.
Hub extension (assembly aid)
Then remove the wheel carefully.
Installing wheel with central bolt
1. Examine the safety components listed below carefully before fitting the wheel.
1.1. Check the wheel bolt for damage.
Wheel bolt (central bolt)
There must be no scratches or cracks on the conical area, trapezoidal thread and inner toothing on the bolt.
Replace the wheel bolt if it is damaged or if you have any doubts.
1.2. Check the lockable wheel bolt (locking mechanism/one per wheel).
Lockable wheel bolt (locking mechanism)
1.2.1. Check that the toothed locking pin is not stiff. After pressing the pin into its cartridge, it must return to its original position with force and without catching.
1.2.2. The toothing on the locking pin must not be damaged.
1.2.3. Replace the lockable wheel bolt(s) if they are damaged or if you have any doubts.
1.3. Before screwing on the wheel bolt, check that the lockable wheel bolt (locking mechanism) is engaged (the locking mechanism must be in the wheel hub).
For safety reasons, only remove the lockable wheel bolt (locking mechanism) in order to check it and then re-insert it immediately in the wheel hub.
1.4. All contact surfaces of the wheel, wheel hub and brake disc as well as the trapezoidal thread in the wheel hub must be free of abrasion, sand, dust or chips.
Apply some aluminium paste on the trapezoidal thread of the wheel hub if necessary.
1.5. Apply some aluminium paste on the trapezoidal thread of the wheel hub.
1.6. Apply a thin coating of aluminium paste on the cylindrical part of the wheel hub.
1.7. Only fit brake discs with driver pins that have been approved for centre-lock wheels.
2. Fit the wheel carefully. Make sure not to damage the brake disc when fitting the wheel.
Use an assembly aid 9794 (hub extension) -1- on vehicles with PCCB (Porsche Ceramic Composite Brake).
When fitting the wheel, the vehicle must not be supported by the wheel to be secured.
3. Check the condition and functional state of the lockable wheel bolt and replace if necessary.
3.1. Pull the lockable wheel bolt out of the wheel hub.
3.2. Check the condition of the lockable wheel bolt and replace it if necessary.
Carry out a function test (element can move axially with automatic return to initial position). Check mechanical state and perform visual inspection (O-ring, inner and outer toothing).
The lockable wheel bolt must not be repaired (O-ring can be replaced of course).
Replace the lockable wheel bolt assembly if it is damaged.
4. Partly disassemble the central bolt if necessary before fitting the wheel and grease the sliding surfaces inside -grey areas (4)- again with Optimoly TA (aluminium grease).
Disassembling and re-greasing central bolt
Generally, there is no need to re-grease the inside of the bolt, except in the following situations:
Cone ring on central bolt
A very high or very low torque is required to loosen the wheel bolt (more than 700 Nm/518 ftlb. or less than 400 Nm/296 ftlb.).
In the event of a jerking, fluctuating tightening torque.
If you feel any stiffness or stip-slick effect when turning the cone ring -1- for the wheel bolt by hand (cone ring -1- turns back and forward). Apply a certain amount of pressure when checking (turning the cone ring to the wheel bolt -arrows- ).
Before driving on race circuits, disassemble the central bolts and grease them again if necessary.
4.1. Remove cone ring -1- from central bolt -3- .
A circlip holds the cone ring -1- in the wheel bolt -3- .
To remove the cone ring -1- , detach it from the wheel bolt -3- by tapping sharply on a wooden base (threaded side facing down to the wood).
4.2. Grease the grey areas -4- of the cone ring and wheel bolt (also the thread) and the three reserve bores on the cone ring with aluminium grease (Optimoly TA).
The three reserve bores must be filled so that they are 1/3 to 2/3 filled with aluminium grease.
Re-insert the washer -2- without greasing it (the washer will be re-greased automatically on both sides during assembly and when the components are subsequently screwed together).
4.3. Insert the cone ring -1- into the wheel bolt -3- in such a way that the circlip engages in the groove on the wheel bolt.
5. Grease the conical surface -1- of the central bolt with a very light coating of Optimoly TA (aluminium grease) before fitting each wheel. Make sure no dirt sticks to it.
Greasing conical surface of wheel bolt
Information
When fitting all wheels, the vehicle must never be supported by the wheel to be fitted. → Lifting the vehicle
Lifting the vehicle
6. Insert the central bolt into socket wrench 9796 -1- (until it engages). Fit the central bolt vertically on the wheel hub and screw it on without tilting it.
Screwing on central bolt using socket wrench 9796
Information
The tightening torque was increased from 500 Nm (370 ftlb.) to 600 Nm (444 ftlb.) in the course of model year 2011.
The higher tightening torque also applies to older vehicles.
7. Use a suitable torque wrench (together with socket wrench 9796) to tighten the central bolt using the three-step tightening procedure.
Tightening wheel
7.1. Step 1 -1- : Tighten central bolt to 600 Nm (444 ftlb.).
7.2. Step 2 -2- : Loosen the central bolt again (slightly) by approx. 60° (1/6 turn).
7.3. Step 3 -3- : Tighten the central bolt to a final tightening torque of 600 Nm (444 ftlb.).
WARNING
Unsecured central bolt
Risk of damage to components
Danger of accidents
→ After fitting the wheel, make sure that the locking pin is engaged correctly in the central bolt.
8. Remove socket wrench 9796 and check that the locking pin -1- has already engaged automatically in the central bolt. The end of the locking pin is then flush with the inner toothing of the central bolt → Wheel bolt secured .
If the locking pin is still at the rear position → Wheel bolt not secured and has not yet engaged in the inner toothing of the central bolt, the central bolt is still not secured and must be secured manually to prevent it from becoming loose.
To do this, turn the locking pin to the left and right using a 1/2-inch square extension until it engages in the central bolt.
This applies to both road and race track use.
When the central bolt is secured, the end of the locking pin -1- will be flush with the inner toothing of the central bolt.
Wheel bolt secured
9. Fit the crested hub cap -1- into the central bolt so that the positioning finger is in the opening groove ( -arrows- ).
Then press the cap in until it is seated securely. Grease the rubber ring on the cap lightly beforehand if necessary.
Now lower the vehicle.
Fitting crested hub cap
– Tightening the central bolt in an emergency
If you do not have the correct torque wrench required to tighten the central bolt to the prescribed high tightening torque in a breakdown situation, the emergency tightening procedure must be performed.
– 1. The central bolt must always be fitted using the original tool (stored in the luggage compartment).
– 2. Tighten the central bolt with a long lever using a lot of force. Then loosen the central bolt again slightly (by approx. 1/4 turn).
Use a torque wrench to tighten the central bolt to exactly 100 Nm (74 ftlb.).
Draw a line at the marking ^ 100 Nm on the wheel.
Emergency tightening procedure
– 3. Tighten the central bolt further with a long lever until the square (Stop) marking is aligned with the line you made on the wheel.
This tightens the central bolt sufficiently to allow you to drive to the next qualified workshop.
– 4. Tighten the central bolt immediately (at the next qualified workshop) to 600 Nm (444 ftlb.) using the three-step tightening procedure.
Old 07-16-2011, 07:38 PM
  #112
911rox
911rox's Avatar
hey John,
Just ran out to the car and read the supplemental on CLs... The Piwis info circulating is definitely out of date or just not updated...
The documentation provided with the CL recall specifically states in bold writing that the wheels must be torqued to 600Nm. There is no seperate section for track use etc etc...
I think the answer to your question above is a combination of c, d and e...
Hope this helps...
Old 07-16-2011, 07:53 PM
  #113
911SLOW
Admin
911SLOW's Avatar
Yes found it just before your post and have it with bolt letters.
Now all they have to do is remove the old TI from the system. Independent workshops rely on it..
Old 07-16-2011, 08:21 PM
  #114
Larry Cable
Larry Cable's Avatar
Received 3,614 Likes on 2,349 Posts
Default recall notice
see below:
Old 07-16-2011, 08:27 PM
  #115
911rox
911rox's Avatar
Good to see PCNA know whats going on, shame the dealers don't... Your spare bolts will be changed. Great to see...
Old 07-16-2011, 08:31 PM
  #116
Larry Cable
Default Suppliment
images below, PM me if you want a .pdf
  #117
Larry Cable
+1, I was already having a "discussion" with my dealer about this very issue, nice to see that PCNA are on the ball!!!
Old 07-16-2011, 08:34 PM
  #118
Larry Cable
See recall notice ... they should be replaced by servicing dealer.
Old 07-18-2011, 03:41 PM
  #119
Carrera GT
Wordsmith
Carrera GT's Avatar
Originally Posted by Larry Cable
I meant of the damage ...
Here's some nasty looking wheel damage that, in my humble, is not a risk of failure, but clear evidence of the whole assembly not functioning as intended. Some say relative movement of any component is absolutely intolerable, others assume that the nut will move on the thread and eventually bind on the splines. I say the splined locking pin is a safety mechanism, not part of the assembly design in terms of securing the wheel -- if the safety mechanism comes into play, then it is preventing the continuation of a failure. Once a safety mechanism is "triggered" there is, by definition, a failure in the system.
It's easier to see the images I uploaded (5) at Picasa, to zoom in to full resolution if you want to see the detail up close. Just click on the pic, below and then scroll through the album to see the other pics.
Old 07-18-2011, 03:45 PM
  #120
Larry Cable
WOW ... thanks!
Quick Reply: The Center-Lock recall...
