Champions and Intrax 4-way on Frog RS
Do you have a side shot by chance? Been thinking about just that combination on my '3
Just installed InTrax on my GT3 last week. I've started to sort out the adjustments. All I can say is "wow."
I never thought that you could go sailing sideways over the curbing entering the bus stop at The Glen and not miss a beat.
The suspension is very stiff on the smooth stuff and very compliant over the bumpy stuff while cornering.
If anyone else has this set-up, I'd like to talk to you about various adjustments that you may have tried.
On the rear I found the car would "pogo" exiting slower corners on the power. This was resolved when I increased the rebound damping. Intrax default is -25, Oakley run -14 on their car. On a smooth circuit (eg Silverstone) I ran with -10. I also went to 28 on the high speed bump and 10 on the low speed.
Try that and let me know how you get on.
PS - what tyres are you running?
I've done two trackdays since I had them fitted.
My initial observation is that the front end of the car is significantly better. Much more neutral, great turn in without being nervous. Supple over the kerbs, yet very tight control under braking and in high speed corners. Pretty clever stuff. I haven't adjusted the front at all yet. Feels like it working really well. I'm running -12 rebound, 10 high speed compression and 7 low speed compression.
The rear I found a little stiff and bouncy to begin. As noted I've since increased rebound which greatly reduced the bouncing motion. Loads of grip at the rear. Very safe and benign. Still some improvement to come though I think. Incidentally I'm running the standard rear stabiliser bar on the middle setting. Before fitting the intrax I'd resorted to the new GT2 rear bar to get the car turning in better.
I'm running the original fitment Pirelli Corsa System tyres. They work a lot better with the intrax dampers than the stock dampers that's for sure. Going to try motorsport Corsa's next now they are available in 19" sizes.
I'm off to Spa this weekend for a couple of days on track. Henk the founder of Intrax is coming along to help setup my car and 3 others (two other 997RS's and one 996RS).
Will report back on our experiences.
Scott,
I'd love to compare settings. I just got back from Watkins Glen and Summit Point Raceway. As with your observations, I left the front compression as recommended and tightened the rebound. The rear I adjusted the same as your's and Oakley's.
What I found was that in high speed sweeping turns, including running over curbs and bumps, the car was completely composed and stable. On slow speed, tight turns, the car would under-steer like a pig (especially if I was on the throttle). My sway bars were set to one hole from firm in the front, and full soft in the rear. I just couldn't get the car to rotate with this set up.
The next day was raining, and I decreased all compression settings by -4 and moved the front sway bar to the middle setting but I still had tremendous under-steer.
I think that the bars need to be set equal front and rear (in the middle) to gain the best results. I was also wondering if adjusting the rebound or compression in the rear or front as well would decrease the under-steer in the slow tight turns when you're on the throttle.
Let me know your thoughts? Also, I'm running the stock Pilot Sport Cups which are known to increase under-steer.
Scott,
