Resonated over axle pipes (OAP) recommendation?
Hi all,
I'm running a BGTS4.0 with a Cargraphic valve controller (VC) and really enjoyed that setup for about a year (exhaust is fully stock otherwise). I know some people complained about resonance/drone/boominess with VC at low RPMs, and actually I do hear a bit of resonance at that range, but it didn't bother me at all.
I recently added Flat-6 (non resonated) OAPs to the mix, since the exhaust note felt very muted to me (very constant tone, no burbles etc.)
I am extremely satisfied with the change in character, I finally hear some nice burbles and tones! (and it's not overly obnoxious). It also makes a nice pop sound while upshifting or downshifting (6 speed), It's exactly what I was looking for!
However - I'm a bit overwhelmed by the resonance/drone/boominess now, especially in lower RPMs
The resonance/drone/boominess is mostly solved by sticking with original PSE programming (disabling the VC) but it really sucks not to be able to hear the engine in lower RPMs + other annoyances with the original PSE
I was thinking about swapping to a resonated OAP (specifically Soul resonated) since I understood it eliminates those frequencies, especially in lower RPMs and also lowers the total volume increase a bit, which would be nice
My question is - does the Soul resonated OAP still retain the "character change" that comes with the non-resonated OAPs? (can hear burbles and pops more clearly, exhaust sounds less muted)
If the only change with the resonated OAP is a volume increase over stock, that would not be very interesting to me..
Thanks in advance!
Thanks in advance!
The 4.0 does not burble and pop, so no, you won't hear either of those.
Basically my question was how much the resonated OAPs would dampen that (if they just dampen the "boomy" frequencies that would be best) vs. the non-resonated ones (which I have right now)
Just invest in a complete system.
Most of the frequencies you dislike are created by the rear, and can become nearly in-perceivable with the right OAP/Back Box combo.
subwoofer (07-12-2024)
I would think that any resonated OAP would tame some of the burbles and pops, the question would be by how much.
I went from the OEM OAP to the open Akra OAP and the difference for hearing pops and gurgles was incredible, but it definitely unleashed the drone aspect as well.
You need some owners with the Soul resonated OAP to chime in, and maybe reach out to @Soul Performance I am sure they have some data and possibly even some video/audio.
So you're saying that even with a resonated OAP it will still be very "boomy"?
I haven't gone the full route since I just wanted to get a bit more character out of the exhaust, without dropping 5-10k
I had AKRA OAPs prior to my Kline. The OAP's alone made the car more alive, though the back-box was for me where the system failed to produce a preferred tone. Then enter a back box w/X-Pipe paired with resonated OAP's and the satisfaction was..... well, you gotta hear it to believe it!
I get the financial side of things. I too was slightly reluctant to throw money at the full system, but it was worth every penny.
matt0520 (07-12-2024)
I'll give my response, firstly by the description "very boomy" are you referring to drone now? Also you added 'very' to the description? I would say the OEM OAP and resonated OAP tame the sound, it is the open OAP that make the big change in all of this.
And as @BoxKing pointed out the rear section plays a huge role in how the entire system sounds, if you are only going to do the OAP, for the most part you are only making the OEM system louder and uncorking a little of the pops and gurgles.
If you were directing this question at me... ?
I was optimistically hoping that the resonated ones would have OEM-like drone but wouldn't attenuate the cool stuff out (pops and gurgles)
But if I understood your answer you're basically saying that, unless you're changing the rear box, drone + volume + pops and gurgles all come together, and the R-OAP is somewhere between OEM and OAP
Perhaps a good person to connect with would be @RoadrunnerGTS . He sold me his Soul resonated OAP's and ended up buying the full Kline SS system, so can comment on both I think?
I absolutely LOVE the sound of the Soul resonated OAP's...I wanted something 'more' than stock, but not loud, and it gave me what I was looking for for about $1000.
I'm not handy and don't have a lift, so if I went Kline would have to pay for an install, so a full Kline SS with install would be around $6k after selling the R-OAP's and while money is no object for many on this forum, for me it is and the delta on cost is just not worth it for me currently. (kid entering college soon)...I will eventually go with the Kline in the years ahead though (I think).
I do not notice significant pops and burbles around town driving fairly easy...
Only like 4K if you get roughly 1K back from resale of your OAP's ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
So with the R-OAP is it just a volume change? (like I mentioned, with non-resonated OAP I feel it also changes the exhaust's character in a really good way)
Yeah I have Flat6 OAPs and mine does not burble or pop (Nor do I want it to)
It does burble, just not as much as the 981. With the stock OAPs you can barely hear it since it's so muted. With the Flat 6 OAPs it's much more pronounced, that's what I mentioned in my post.
That being said. OP i think you need to get a full system to achieve what you are looking for. There are some other systems out there that arent as expensive, but i'll be honest, i think the 2 best systems i've heard thus far (via youtube) have been the Kline system and the Dundon system, the latter being massively expensive. What you could try to do if you wanted to stay in budget is to purchase a resonated OAP set and then change out your headers. This would keep the burbles while muting some of the drone. Or you could stick you old OEM OAP set back in and switch out just the headers. Basically its all about fighting sound restriction and right now with your current system the cats on your header is whats causing that low end drone and boom that you dont like.
