RS 3.89 R&P and 6th gear conversion..
#106
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_5974_5ccf3071f8abbe49a7138ded90664db273109ec4.png)
should have my Euro spec 07 RS back next week with 3.89 r&p, 6th gear, Guard LSD clutch pack, Sharkwerks 4.0 clutch flywheel kit, Sharkwerks kit coolant lines pinned, Dundon headers and full D4 package -35lbs plus 40hp and 25lbs tq, Function First shifter kit and cable ends, surface transforms rotors and Pagid pads, OZ Superforgiata wheels -35lbs, Antigravity lithium battery -35lbs, new OEM engine mounts, OEM titanium RS center muffler -8lbs
can’t wait to report
Wow, that is one hell of a list of upgrades to do at once. Can’t wait to hear the impressions, and my condolences to your wallet.
#107
Has anyone done the GT2 or GT2RS 6th? I like the idea of a little extra RPM for road trips as my closest track is 6 hours away, and I do usually one cross country trip a year.
Brian Himmelman (05-11-2024)
#108
LOL, you're going to have no idea what's doing what. It's going to be a drastic difference. What a treat.
The following 2 users liked this post by RAudi Driver:
Brian Himmelman (05-12-2024),
SR20Fastback (05-12-2024)
#110
does anyone know anything else while engine is out ie what a cam actuator bolts and what has to be done to correct? tks
#111
The following 2 users liked this post by JpCrp:
LCCHOU (05-16-2024)
#112
Cam bolts on .1RS are not a known issue. Can inspect and remediate if you want, but I don’t think it’s a major issue.
Edit - Also front and rear main seals if you have leaks or just want to be super proactive.
#114
Just wanted to update as I got the car back after a long month of waiting. As others have attested - totally transformed. Truly feels like a car with 50 ft/lb more torque. I wound up going with the full RS 4.0 treatment, and glad I did. For others who’ve asked if the slightly lighter 4.0 flywheel makes a noticeable difference to the 7.1RS unit, I can’t say that it really did. It feels maybe just a bit zippier, but it’s nominal.
However, the entire experience felt through the drivetrain is definitely somehow smoother. Not sure what that’s about. I got new synchros due to some premature wear, so maybe that aided ? Regardless, the net result is fantastic. Pulls so much more quickly through the gears. Really amps up around town enjoyment. Guard diff also massive, massive improvement. Rear end so planted. It waggled a bit under super hard high speed braking before. Now straight as an arrow. And absolutely stuck to the road on turn-in and exit. Great mod.
Lastly, I shopped around for the 4.0 FW and clutch package, and between FVD and Sierra Madre, found the FW for $580 and the pressure plate for $880. Both quite a bit cheaper than others I searched.
The following 5 users liked this post by jreifler:
Brian Himmelman (06-01-2024),
changster123 (06-02-2024),
Robocop305 (06-01-2024),
Vocan (06-01-2024),
widers911 (06-01-2024)
#115
I’ve got the RS R&P I never used in my car brand new if someone wants to avoid international shipping.
#116
#117
I'm definitely going to have to adjust to the shift point change. On my regular switchback-filled forest drive, I was upshifting to 4th much sooner on the straights. I kept wanting to go into 2nd as I used to do for tight 90 degree bends, but I really didn't need to. It rockets out in 3rd now. I for sure think it's a 3-4-5 car on any track now.
The following 2 users liked this post by jreifler:
Vocan (06-01-2024)
#118
I bit the bullet and ordered the 3.89 R/P + taller 6th for my base GT3.
Now I'm planning ahead for "while we are at it" stuff -- particularly the synchros as I got the car used, and have no idea how well the previous owner drove it despite relatively low mileage of 10,000 miles. The gearbox has no noticeable issues in shifting.
I'm thinking only replacing 2nd and 3rd gear synchros only, given the low likelihood that the higher gears would have a problem. I do double clutch into first gear on streets, as I don't always wait for the car to come to a complete stop before jamming shifter into 1st. Or should I do 1st and 2nd instead?
With that in mind:
1. Looking at part numbers online, do all gears come with steel rings for these 997.2 cars from the factory? Seems like some threads are saying 1st and 2nd are brass, but then I couldn't really find those part numbers. If some are brass, will changing 2nd to steel help with durability without major sacrifice to street driveability?
2. Do I replace the ring+cone for 1st and 2nd gears, and ring-only for 3rd? Or are the cones usually not something that wears out that easily/quickly. Part numbers:
3. Has anyone tried the synchros from Rauch & Spiegel instead of factory/OEM ones on their 997 cars? (theirs seem to have "carbon" in their synchros as well)
The car is expected to be driven on the street mostly. Just looking to get something more durable and keep the shifts enjoyable, while not adding a horrendous amount of NVH to the car.
Thanks in advance
With that in mind:
- 95030461311 - Cone for 1st & 2nd (~US$450 a piece?)
- 95030461120 - Ring for 1st & end (~US$100 a piece)
- 92830421130 - Ring for 3rd to 6th (~US$100 a piece)
Thanks in advance
KingSize.Hamster (07-10-2024)
