RS 3.89 R&P and 6th gear conversion..
#61
Ive been browsing a while and haven't seen anything below $3000 even when on sale for a 4.0 rs clutch conversion kit. Or are you talking about piecing the parts together and having it be cheaper?
#62
Looking forward to seeing what you choose to do man. I am loving my stock 7.1 RS set-up w 4.0 clutch flywheel, but shifting it to the better ring/pinion and regear takes it up 2 notches. I have not wanted to spend the $'s for this.....yet. Living vicariously through your spend will likely make me jealous, and require my prying the wallet open. Go for it, force my hand please ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
jreifler (02-15-2024)
#63
The "kits" are expensive because whoever is selling them has their markup factored in. You can easily purchase the individual parts yourself if you wanna save money.
#64
#65
Sure.... Obviously you don't need all those parts if you already have a 3.8RS set up.
997GT3RS 4.0 clutch
964.102.239.81 LWFW
964.114.143.31 Ring gear
928.102.151.01 FW bolts (9x)
931.102.111.02 Pilot bearing
997.116.013.92 Clutch disc
997.116.027.91 Pressure plate
900.067.103.01 Pressure plate bolts (9x)
950.116.813.30 Guide tube
999.270.070.02 Guide tube bolts (2x)
944.116.080.01 Release bearing
997.2GT3RS ring and pinion / 6th gear
997.302.911.90 3.89 (35/9) ring and pinion
997.302.956.90 0.88 6th gear
997GT3RS 4.0 clutch
964.102.239.81 LWFW
The following 4 users liked this post by powdrhound:
#66
997GT3RS 4.0 clutch
964.102.239.81 LWFW
997GT3RS 4.0 clutch
964.102.239.81 LWFW
$4166 for the r/p and the 6th gear pn says discontinued and I don't see an updated part number for it.
JpCrp (02-15-2024)
#68
~$2,000 for the clutch + flywheel from here https://lufteknic.myshopify.com/coll...ant=3138009796
Not sure which PN's they are exactly selling.
powdrhound (02-16-2024)
#70
I agree, definitely worth a call to clarify.
#71
997GT3RS 4.0 clutch
964.102.239.81 LWFW
997GT3RS 4.0 clutch
964.102.239.81 LWFW
#72
What is the average cost to have a transmission upgraded with the 997.2GT3RS ring and pinion / 6th gear? I know the ring and pinion is around ~$4500 and 6th gear ~$1400. What about labor?
rafter75 (02-16-2024)
#74
kevin @ umw sells a 4 liter clutch kits….reasonable price if recall right
from umw-Kit includes
Sachs Race Engineering 487 Pressure Plate "Bolted"
Genuine Porsche 4.0 Liter GT3RS Clutch Disk
Flywheel , Ring Gear , Pilot Bearing
Pressure Plate Bolts and Flywheel Bolts
Throwout Bearing , Guide Tube , Nylon Bushings
Clutch Lever Shaft Seals , Fork Shaft Bearings
$2,895.00
#75
