Making a Durametric Coding options Manual
Old 10-01-2015, 03:32 AM
floatingkiwi
floatingkiwi's Avatar
HOW DO WE STICKY THIS THREAD?
Old 11-08-2015, 08:00 PM
floatingkiwi
Updated.
Old 11-09-2015, 07:05 PM
StormRune
StormRune's Avatar
Nicely done! I missed thread when you first posted it. I've also done several of the same changes you have. The only contribution I have is:
At row 313 in the original Excel you sent out: "Spoiler Function Depends on Acceleration"
I enabled this one. Under heavier acceleration (roughly half throttle or more), the spoiler (or turbo wing) will deploy earlier than normal a speed of around 37mph. It will always deploy at roughly 75mph even with this enabled (as long spoiler function in general is set to active).
Thanks for the hard work on putting this list together.
Old 11-09-2015, 08:50 PM
Cloudspin
Cloudspin's Avatar
Originally Posted by StormRune
Nicely done! Thanks for the hard work on putting this list together.
+997
Old 11-09-2015, 09:50 PM
destro
destro's Avatar
This is great. If you put it in google docs it will be MUCH easier for people to comment and contribute. Then you can accept / reject the potential updates.
Old 11-10-2015, 04:44 PM
floatingkiwi
Thanks! 997.1 or .2?
Old 11-10-2015, 04:53 PM
floatingkiwi
Good idea - I'll have to figure out how to do this!
Old 11-10-2015, 05:43 PM
StormRune
StormRune's Avatar
I can only confirm it is working on my 997.2.
Old 11-10-2015, 06:44 PM
shardul
shardul's Avatar
nice info thank you!
Old 11-10-2015, 11:32 PM
floatingkiwi
I'll work on getting it into a google docs format tonight.
Old 11-11-2015, 02:57 AM
floatingkiwi
updated with a google docs link instead. PLease let me know if you can't access this for any reason.
Old 11-11-2015, 03:45 PM
malahhaor
malahhaor's Avatar
thank you for the hard work.
Old 12-10-2015, 05:38 PM
floatingkiwi
Minor updates. I need people to help out with this!!
Old 01-11-2016, 06:03 PM
TommyV
TommyV's Avatar
floatingkiwi, are you using a Professional or Enthusiast Durametric? What about others responding here? I'm buying a Durametric and it doesn't seem like the Pro is worth the extra coin unless I need more than 3 VIN capability.
TIA
Old 01-11-2016, 06:10 PM
StormRune
StormRune's Avatar
TIA
As long as you only want to read settings and reset the service interval that is true.
Only the Pro can change coding, all of the options you see listed in the spreadsheet that floatingkimi has been kind enough to document. The Enthusiast version is not able to change the coding of anything.
Quick Reply: Making a Durametric Coding options Manual
