What did you do to your 997 today?
Old 07-27-2022, 06:37 PM
  #13081
ATX_Native
ATX_Native's Avatar
^ If you’re 997.2, look into the IPE Setup.
Closest thing I’ve ever heard to a Carrera sounding like a GT3.
ATX_Native is offline
WheelsB (07-27-2022)
Old 07-27-2022, 06:38 PM
  #13082
Ob917
Ob917's Avatar
yes 997.2, cool I’ll check it out. Thank you.
oh just looked, only valvetronic it looks like. I don’t need all that
Ob917 is offline
Old 07-27-2022, 07:53 PM
  #13083
bogotajoe
bogotajoe's Avatar
covered a few interior parts in alacantara. Weldwood glue and Charcoal Black fabric from Relicate.
bogotajoe is offline
The following 4 users liked this post by bogotajoe:
joes c4 cab (07-28-2022), maekwl (07-28-2022), S85beast (08-01-2022), TerrestrialFlyte (07-28-2022)
Old 07-28-2022, 12:56 AM
  #13084
Gns30
Gns30's Avatar
Default Finally did my steering wheel swap!
Added the 991 steering wheel to my 997.1 finally!!
Gns30 is offline
The following 8 users liked this post by Gns30:
Ailerons (07-28-2022), BLU997 (07-31-2022), frederickcook87 (07-28-2022), joes c4 cab (07-28-2022), maekwl (07-28-2022), quickxotica (07-28-2022), sabotaged (07-28-2022), TerrestrialFlyte (07-28-2022) and 3 others liked this post. (Show less...)
Old 07-28-2022, 02:48 AM
  #13085
Ailerons
Ailerons's Avatar
Another steering wheel swap! Finally got around to doing it this morning.
Ailerons is offline
The following 6 users liked this post by Ailerons:
BLU997 (07-31-2022), frederickcook87 (07-28-2022), maekwl (07-28-2022), myw (07-28-2022), TerrestrialFlyte (07-29-2022), vg247 (07-29-2022) and 1 others liked this post. (Show less...)
Old 07-28-2022, 09:42 AM
  #13086
F77
F77's Avatar
Exclusive Option
F77 is offline
Old 07-28-2022, 10:59 AM
  #13087
fireman
fireman's Avatar
Default New oil pan and oil change.
2008 C4S
fireman is offline
The following 2 users liked this post by fireman:
frederickcook87 (07-28-2022), maekwl (07-29-2022)
Old 07-29-2022, 12:03 AM
  #13088
voidopolis
voidopolis's Avatar
more details please! Backed or unbacked? how was the covering process?
installed pics would be great!
voidopolis is offline
Old 07-29-2022, 01:05 AM
  #13089
maekwl
maekwl's Avatar
@Ailerons from your console I think you have a 7.2. I also do and want a 992 wheel so bad. Did you do the swap? Was it easy or hard? Where did you source?
looks awesome. I love the exposed screws
maekwl is offline
Old 07-29-2022, 11:21 PM
  #13090
pearldrum944
pearldrum944's Avatar
I finished up changing my starter motor and starter/alternator cable today. Wow, everything on this car fights you…. I thought getting the plastic clips from the cable off would be the worst part but getting the alternator back in place ended up taking the longest! All in, the job took me about 5 hours. She turns over so quickly now!
pearldrum944 is offline
The following 2 users liked this post by pearldrum944:
BLU997 (07-31-2022), joes c4 cab (07-30-2022)
Old 07-29-2022, 11:37 PM
  #13091
Gns30
Gns30's Avatar
You ain't kidding, I'm in the same boat!! Putting a new starter, new cable, new Air/Oil separator, new belt and a GT3 throttle body swap in while it's all apart!! Hope I can remember how to get it back together again!
Gns30 is offline
pearldrum944 (07-29-2022)
Old 07-29-2022, 11:47 PM
  #13092
pearldrum944
Ha! That’s too funny! I couldn’t get the alternator around the bolt channel on the idler pulley side. Turns out the bushing on the back mount of the alternator moves, so I soaked it in PB blaster, reinserted the bolt and smacked the bolt with a hammer to push the bushing back, then the alternator slid into place.
Old 07-30-2022, 07:35 AM
  #13093
Johnny DB
Johnny DB's Avatar
Did you guys lower the engine to do this? Gives you a couple inched of much needed room.
Johnny DB is offline
Old 07-30-2022, 09:25 AM
  #13094
Gns30
Gns30's Avatar
I didn't, vertical height doesn't seem to be the issue, it's just everything is stuffed inside, small hands would definitely be a plus. I did crawl under to see if I could reach that bottom starter bolt but that was a no, still trying to figure out how to get it back in without it falling off into the pit of darkness!
Gns30 is offline
Old 07-30-2022, 09:45 AM
  #13095
Petza914
Petza914's Avatar
Received 6,452 Likes on 4,113 Posts
I do and am doing this job this weekend. Mine is more complicated because I first have to remove all the supercharger stuff. Definitely helps to support the more from the edge of the engine carrier and spin the motor mount nuts down close to the bottom without weight on them, where you know you have some thread left, then lower the engine cradle back onto the nuts. In my case I need more space decaue of the supercharger so I actually unthread them all the way and lower the rear of the engine as far as I can until it won't angle.any more.
Petza914 is offline
Quick Reply: What did you do to your 997 today?
