What did you do to your 997 today?
#6556
Took the wife's car to the airport last week and realized it needed some work - steering wheel off-center (no pull though), a little steering wheel shimmy, and some vibration under braking.
So, today, had the car realigned, had the tires road force balanced, and am replacing the rotors and pads. Had 2-piece slotted already so just bought new rotor rings and swapped them over to the hats with new, single use nuts & new Hawk Ceramic (yellow box) pads.
Fronts are completed and I'll do the rears tomorrow, with an adjustment to the parking brake shoes as well.
After the bedding-in process today, better initial bite, and smooth as silk stops from high speed again.
Last edited by Petza914; 02-26-2018 at 10:28 PM. Reason: Added photos of completed rears
#6557
A sunny day after the snowy week. Some great windy roads and good views. Had to leave mine behind as we got higher up and hit thick snow, but my friends 4S is a trooper. Didn't miss a beat.
#6558
#6559
Sir Thomas Lord of All Mets Fans
A little brake upgrade for The DE season
Agency power spacer, made for a 996 but fits 997.1. Spaces out the caliper 10mm. Tarrett brake studs help prevent stripping the hub carrier with frequent brake changes.
Checking fit.
Turbo rotors, 350mm a 20mm increase in size. Should help in heat absorption but mostly increase in brake torque by moving the caliper.
#6561
#6562
Originally Posted by Chris Ferrell
Thanks! It's about 15 miles outside Portland, OR in the NW.
Here is a shot of @z3mcouple's 4S deep in the snow
T
#6563
#6565
You can do it with the rotors and calipers installed - just rotate the rotor so one of the wheel bolt holes lines up with the adjuster. You can stick a flat head screwdriver through the hole and roll the adjuster in one direction or the other depending on whether you want it to engage more or less. I adjusted both sides so I could feel decent drag at 2 clicks, significant drag at 3 clicks (could still rotate it with a lot of force), and couldn't budge it at 4 clicks. It would go up to 5 clicks with a lot of force. When released, both wheels would spin freely without any drag. Held fine on a hill today when I checked it.
Here's what I referenced to get an idea of what's involved and how to locate the adjuster.
Good luck.
#6567
Originally Posted by platinum997
Changed the plugs.
Not a horrible job once you get through the first side.
#6568
Any recommendations on the tools and jacking position? I went to start the car this past weekend after winter hibernation and got a check engine light after a rough idle. I took it for a drive to burn up some old gas and that did not help. I suspect a bad coil somewhere. The car has 52k miles and I was thinking to do my 65k service sooner, replacing the plugs and the bad coil(s) at the same time.
If you do change the plugs, it's much easier to use 2 shorter extensions than 1 longer one. You slip the spark plug socket with one extension into the tube and while holding the end of that extension, you add the second one and then the ratchet. Removing the plug once free is the opposite. Do not use anti seize on spark plug threads as it effects the grounding of the plug - just a drop of motor oil is best.
Good luck.
#6570
Originally Posted by Petza914
Did you have fuel stabilizer in the gas during storage? If not and the car ran fine when you put it away, the gas has probably just gone bad, especially if it was an ethanol blend.
Good luck.
Good luck.
No, I did not use a fuel stabilizer. This winter, I let the car sit longer than previous ones where I had started the car every three weeks or so. What product do you recommend?
Best
