What did you do to your 997 today?
#3601
Sir Thomas Lord of All Mets Fans
Originally Posted by awrryan
Ha! Thanks. I had the same dilemma. Washed, waxed and then went for a drive anyway.
T
#3603
I mopped up a windshield washer tank leak. Must have a crack in the reservoir or a loose hose. Don't know yet, have not looked. Just finished using search function to explore issue.
#3607
Replaced air filters, here is a how to:
Normal car air filter change:
1: open hood
2: loosen wing nut/clip
3: remove air filter cover
4 :change filter
Porsche air filter change:
1: Open "hood"
2:mutter- "WTF!!!!"
3:look for proper torx driver to remove air cleaner cover
4:attempt to remove first screw from recessed location with little or no room to grab screw
5:drop screw in engine bay
6:magnetize torx driver
7:cut hands trying to retrieve screw
8:remove second screw
9:drop second screw
10: repeat 5-7
11: remove third screw
12: repeat 5-7
13: remove fourth screw
14: you know the drill.....
15: screws #5-8 are easy
16: unplug wire harness
17: remove air cleaner cover
18: mutter "wtf" again
19: look for different torx driver
20: remove two more screws holding the actual air filter in place
21: change filters out, reattach with torx screws
22: fit cover back on
23: screws # 5-8
24: attempt to fasten screws #1-4
25: repeat steps 5-7 four more times
26: clip wire harness back
27: sit back and admire what you accomplished in the last hour+ of your life
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
#3608
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
#3609
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
#3610
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
1: open hood
4 :change filter
1: Open "hood"
2:mutter- "WTF!!!!"
9:drop second screw
10: repeat 5-7
12: repeat 5-7
23: screws # 5-8
#3612
That's cool good job. I'm charging the battery. LOLZO.
#3613
The weather was just miserable this weekend in the north west so I finally got around to mounting my sport classic wheels added the side script decals and painted the steering wheel cover the same color as the car. Not exactly an original look but I have been and aways will be a big fan of the seventies RS look.
#3614
Your car is VERY close to mine and what i'm doing to it. Sport Classic wheels sitting in my office, lowering springs on way. Then Getty and decal.....
Nice to see what its gonna look like, not nice in my car won't be unique lol
#3615
