Maintenance: Replace Serpentine Belt
Old Nov 10, 2016 | 02:12 PM
  #76
voiceprint1's Avatar
voiceprint1
Grooving on the rollers that is irregular in nature?
Old Nov 10, 2016 | 02:30 PM
  #77
Schnell Gelb's Avatar
Schnell Gelb
By the time any grooving appears it is probably time to replace the bearings.The bearing +pulley comes as a complete assembly. Before you fit the new,smooth-faced pulleys, check the grooved pulleys for alignment.Use a straightedge across their faces and shim if necessary/where possible.
Old May 6, 2020 | 02:47 PM
  #78
tegraphile's Avatar
tegraphile
Originally Posted by holden997
I just replaced my belt a week ago, It was a lot easier to slide the last step around the lower yellow idler pulley. NO screwdriver needed just a 24mm socket and a breaker bar. A 15 minutes task.
Thank you! I was getting so frustrated, until I saw this! Way easier over the lower idler. You saved my knuckles and then some!
Old May 11, 2020 | 04:04 PM
  #79
campbesl's Avatar
campbesl
Default Tensioner Replacement DIY Needed
Following the instructions in this DIY, I replaced the three pulleys and the belt on my '08 C4S . However, I still want to replace the tensioner but I need guidance on what to disassemble to get to it. Can anybody direct me to such information?
Thanks.
Scott
Old May 11, 2020 | 05:19 PM
  #80
Vince Vincent's Avatar
Vince Vincent
Did this last week! Amazing write up, cleaned up my intake while it completely off as well.
