Uneven level of soot on exhaust tips! (997.2)
I recently learned that my 2009 c2s left side muffler tips get dark much faster than the right. Many forums say that for 997.2 this could lead to a scored cylinder #6.
my oil consumption is also at about 1 liter / 1000 km with its current 65000km
i just want to know if this uneven level of soot is uncommon among 997.2 owners? It seems some take it as a serious warning sign while some others ignore it as normal...
![](https://i.postimg.cc/xdp8s4w1/139548-E5-26-E1-426-D-AD8-B-BE8-DFB25414-D.png)
If you don’t clean them they will look the same after a while. Iirc the left side on a 997.2 represents cyl 123, unless you have Center muffler delete x over pipes. Cyl 456 are on the right side. Cyl 6 bore scoring typically occurs on 997.1 cars. On 997.2 cylinder 1 seems to be the problematic one in a few documented instances which is left side tail pipe on non modified exhaust. That being said 1 litre / 1000km does seem high as many .2 burn little to no oil. It is within the range.
I am amazed how little oil my 2010
997.2 S uses. I had the oil changed
during my 40,000 service and have used
less than 1/2 quart since. I am at 46,500
miles now. When I drive it, I like to
be in the upper rpm range of the car.
You're 1,500 miles past when you should have already changed the oil again if you want to keep oil consumption on that engine low like it is now. Yes, I know the manual says 10,000 miles or something ridiculous like that. If you do UOA you'd know just how ridiculous that interval is based on metal wear, viscosity, and TAN/TBN numbers.
BucketList (05-04-2020)
uneven soot is bad news from my experience.
The following 2 users liked this post by Bruce In Philly:
johnm864 (05-20-2024),
JustinCase (05-04-2020)
TheTorch (05-04-2020)
Question: Are people saying that soot on both pipes is generally not concerning but soot on one pipe is very concerning ?
This seems somewhat illogical to me, but maybe I don't understand well enough what causes soot in a non-bore-scoring scenario.
