My PPI report came back today
Old Jul 21, 2021 | 03:08 PM
mhitchi's Avatar
mhitchi
Default My PPI report came back today
Apparently this 911 was able to carry more than 3 passengers!
Old Jul 21, 2021 | 03:32 PM
nerdnic's Avatar
nerdnic
Mouse nest? o.o
Old Jul 21, 2021 | 03:47 PM
Hootsama's Avatar
Hootsama
Originally Posted by nerdnic
Mouse nest? o.o
What, you aren't familiar with the Mäusenest option code MN1?
Old Jul 21, 2021 | 04:44 PM
groovzilla's Avatar
groovzilla
One of my 996 C4s's had evidence of mice chewing wires in engine compartment. Apparently fairly common since warm engine bay is nice place to set up a home.
Old Jul 21, 2021 | 05:55 PM
mhitchi's Avatar
mhitchi
So given the PPI… would you guys be comfortable buying this car?
Old Jul 21, 2021 | 06:32 PM
Tkersting's Avatar
Tkersting
I don’t see anything that would worry me assuming the mice didn’t chew wires and cause electrical damage. Tires are a wear item and the clutch switch is a pretty easy DIY fix (if you want). If the car ticks your boxes I don’t see anything here that’s alarming for an older car.
Old Jul 21, 2021 | 08:05 PM
mhitchi's Avatar
mhitchi
Thanks @Tkersting I guess the only thing that gnaws at me is that the 40000 service was not done for the spark plugs and air filter (.car has 45k). I definitely need the air filter and element done since it sounds like it was a mouse toilet. Would I be unreasonable countering with getting the spark plugs done too?
Old Jul 22, 2021 | 03:17 AM
sandwedge's Avatar
sandwedge
Mouse nest? o.o
How the hell does a mouse get into the cabin air filter? Tight quarters would be an understatement to begin with and at least to me that compartment would seem almost intrusion proof save for small bugs with wings perhaps.
Old Jul 22, 2021 | 04:32 AM
Mozella55's Avatar
Mozella55
Found: Mouse nest in ventilation system.
Fixed: Installed cat near cabin air filter. ..............................$300 (It is a German Rex cat)
Old Jul 22, 2021 | 07:27 AM
Butzi 997's Avatar
Butzi 997
You're not getting a DME?
Old Jul 22, 2021 | 08:08 AM
mhitchi's Avatar
mhitchi
Forgot to mention that… nothing higher than range 2
Old Jul 22, 2021 | 08:35 AM
4Driver4's Avatar
4Driver4
This is a great example of why I don't jump on board when people start saying that a PPI is critical to any purchase. There really isn't anything on this cursory PPI that OP couldn't have observed during an inspection.
Old Jul 22, 2021 | 08:38 AM
Butzi 997's Avatar
Butzi 997
Cool, mhitchi. Delete mice, proceed and enjoy!
Old Jul 22, 2021 | 09:24 AM
Petza914's Avatar
Petza914
Cabin air filter is at the opposite end of the car.
Old Jul 22, 2021 | 09:27 AM
Petza914's Avatar
Petza914
You should do plugs and coil packs if they haven't been done in this cars life. You're also entering the water pump failure mileage range (45k-65k) so be prepared for that. I would also check the coolant expansion tank for hairline weaknsoots that will become leaks. Change that when you decide to do the water pump as you have to empty the system anyway. New serpentine belt at that same time.
