Repairing my PDK Gearbox Experience & Guide
Old 06-21-2022, 09:19 AM
  #91
CLAYTON.C.RALEY
CLAYTON.C.RALEY's Avatar
Did you ever find out the bearing size or where to get the bearings?
Eurocomp (07-21-2024)
Old 11-29-2022, 10:57 AM
  #92
lalawoo_chen
3rd Gear
lalawoo_chen's Avatar
Originally Posted by Damien Law
About me:
Hello all, my name is Damien Law, you address me as Damien. As someone who fixes transmission(DSG MOSTLY) for a living, I always like to try new solutions.
THIS DIY:
This post will be about replacing displacement sensor on Porsche 987 mated to a PDK gearbox, using new sensor made by T-Design (http://t-design9.com/porsche_PDK_dis...on_sensor.html).
The procedure is mostly the same for all variations of PDK on 997, 991, 987 and and 981 models. The sensor is not available from Porsche at all, but the new unit is manufactured by T-Design. This repair saves car owner from replacing the whole gearbox.
My PDK experience:
I have driven many cars with different variant of double clutch designs including BMW's famous DKG, Audi & VW's famous DSG, Ferrari's DCT, McLarens' SSG, Ford's DPS trash & etc. Porsche's PDK is by far, no doubt that from all the dsg produced out there, nothing beats the experience of Porsche's PDK in the 997,991, 987, 981 & more (Macan & Panamera does not count). The response is just amazing, downshifts are just instant, it is almost that the PDK system has 100% synchronization with your brain at 0% latency. You must be thinking that I am overexaggerating, but I can assure your I'm not.
PDK Flaw
Just like many other double clutch transmissions out there, Porsche's PDK has 1 major flaw and that is the distance sensor located inside the rear section of gearbox. You can find many useful info about this specific PDK in the following thread: Guide to Repairing a PDK Transmission
In this thread, I will be showing you how I fix PDKs with this specific issue.
Fault Code Present:
You might get faults like the following but not limited to:
P1731: Shift rod 1 displacement sensor
P1732: Shift rod 2 displacement sensor
P1733: Shift rod 3 displacement sensor
P1734: Shift rod 4 displacement sensor
P17XX: 5V ... displacement sensor (don't quite remember this one)
If you get any of these faults, it is very likely that your displacement sensor has failed or is failing. If you can't be certain, always refer to the data values, they are helpful.
Before replacing displacement sensor your must:
First: Drain all oil & store them in a safe place where it wont be contaminated with debris or water.
Second: Pull the gearbox out of the car, have it come down & the job can be done easily.
Third: Once the gearbox is out & placed somewhere that is workable with. First, you will notice that the gearbox is only 2 piece of housing mated to each other. In this process you will only need to work on the rear section(opposite of input shaft) of the gearbox to replace the displacement sensor.
Fourth: Only in the rear section, undo all T45 sized bolts & I mean ALL.
undo bolts circled in red, there's more below, you get the idea...
don't forget this bolt too
Fifth: In this step, you will need to remove the 2 sealing caps. I was able to pry it out slowly with great amount of patience without completely destroying it just so it can be reused.
remove the 2 black sealing caps. Do it however you feel that is the safest way if you want to reuse these. Mine does not look too good because I pry-ed it out at least 5 times.
Sixth: Once the caps are out, you will need to undo the bolt from the top cap side and unclip the snap ring from the bottom cap side. Unfortunately, I did not snap pictures for this step, but it will be a pretty obvious procedure once the caps are out of the way.
Seventh: In this step, a special tool will be required. I'm not too sure if this tool is buy-able but we managed to make one ourselves(pictures below). We start of by tightening the tool to the housing, then places 2 thick and correctly sized washers between the 2 shaft and the special tool's screw. Slowly tighten the 2 screws on the special tool and the housing will come right off. If the screws are very tight and the housing wont budge, it is likely that you have missed a bolt that was suppose to come off. I can't really describe how this process should feel so good luck
we made this ourselves, not too elegant but it works
you see the two screws between the tool and the housing? the washers goes in between
this picture illustrates pushing out press-fit shafts out of the rear housing using my home made tool
Eighth: Once the rear section it out, you should be able to see the displacement sensor. And if you don't, you are probably not working on a PDK.
that's the displacement sensor
Ninth: Removing the displacement sensor is pretty easy. Just undo 3 bolts from the displacement sensor, undo 2 bolts for the speed sensor and lastly, remove the clip at the female connector of the sensor and push it out of the housing. As easy as ABC.
unbolt them
The Last Step:
Out with the old, in with the new displacement sensor (only at T-Design). Once that is done, just reverse the process and perform calibration(with part replacement/overall procedure) with PIWIS II or III.
I was lucky enough to source once from T-Design and it works like a charm
This is their complete guide on how to prepare the sensor for installation >> Instruction for Displacement Sensor by T-Design
If you have any questions, just ask and I will reply as much as I can.
Some picture of the sensor that I sourced from T-Design
the aluminum part came and I soldered it to the harness
Thanks a lot for sharing!
I am replacing the black cap and together with the plastic plug sort of thing. I had difficulty of put them together and broke all the plastic parts when I tried to push them with some tool. They are just too tight fit.
Is there any good way of doing it?
Old 01-15-2023, 01:16 PM
  #93
teevirdi
teevirdi's Avatar
HI all has any one removed the rear case off one of these gearbox's in the car on a 991 4wd ? or has everyone been removing the gearbox first and then splitting them on the bench ? I have done the Cayman/boxster ones without removing the complete box.
Old 02-10-2023, 10:28 PM
  #94
gman3280
gman3280's Avatar
987.2 Pdk here. Apparently my osg ls wasn’t shimmed properly so I need axle bearings and races. Anyone have a parts source?
Old 04-28-2023, 10:47 AM
  #95
blepski
blepski's Avatar
Has anyone been able to source or purchase the special tools required for the case disassembly or re assembly? These are the only ones I've found wondering if anyone has experience with them. https://www.ebay.com/itm/16585251692...&segname=11051
Also, when replacing the case screws with steel, has anyone found ones that are as close to "OE" type ( torx) and appearance ( rounded heads)? What are the dimensions?
Thank you!
Old 04-28-2023, 02:11 PM
  #96
PV997
PV997's Avatar
Received 1,519 Likes on 651 Posts
Thank you!
Most of the people here have fabricated their own puller using a steel plate, threaded stock, and nuts/washers. Beyond that there aren't really any special tools needed that aren't available from traditional tool manufacturers. That set you linked does look interesting though, but the price is misleading at $162. Shipping to the US is another $169 on top of that.
Nice to see more and more stuff coming on the market specifically aimed at PDK repair but personally I'd pass on this set and just stick with homebrew.
Old 04-30-2023, 06:02 PM
  #97
Dynamicp
Cruisin'
Dynamicp's Avatar
Default PDK Tool
I'm in the middle of replacing my distance sensor in my PDK ZF.. two questions- what tool is used to close the case or what are the size threads at the end of each shaft.. I can craft a tool. Second, what is the right gear oil. Thanks in advance!
Old 04-30-2023, 08:09 PM
  #98
stjoh
stjoh's Avatar
This is what I used to fab a simple press tool. I used the OEM oil BTW.
1 M22x1.5 70mm Bolt BFT22X1.5X70FBLK Belmetric
1 M22 Nut NRH22X1.5BLK Belmetric
1 M22 Washer WFHV22CLZ Belmetric
1 M24x1.5 70mm Bolt BSH24X1.5X70 Belmetric
1 M24 Nut NRH24X1.5BLK Belmetric
1 M24 Washer WFHV24PLN Belmetric
1 Steel tube 2" OD 0.095 thickness 3/4" length
1 Steel tube 1 3/4" OD 0.095 thickness 3/4" length
The following 2 users liked this post by stjoh:
Dynamicp (04-30-2023), thesaintusa (12-18-2023)
Old 04-30-2023, 09:17 PM
  #99
Dynamicp
Cruisin'
Dynamicp's Avatar
Awesome!! This is exactly what I was looking for, Thx U!!
Old 05-01-2023, 04:56 AM
  #100
sandwedge
sandwedge's Avatar
Received 1,041 Likes on 736 Posts
Impressive project. Especially since PCNA won't even allow their own dealerships to do this. Ask me how I know. Just glad I had extended warranty for the $20,000 distance sensor replacement or a rebuilt PDK unit. I don't know what I got back but the broken PDK due to the distance sensor was shipped to Germany and I'm guessing I got a rebuilt PDK they had in stock installed rather than the repaired broken one from my car since it was fixed in 3 or 4 days. With a 2 year warranty.
Hope you're successful. Please keep us posted. I'm curious.
Old 05-11-2023, 11:31 PM
  #101
Dynamicp
Cruisin'
Dynamicp's Avatar
Thumbs up PDK Repaired
Followed all of the steps, PDK repaired~~! While I had things apart cleaned up the bottom, parts, and added a backup camera!!
The following 3 users liked this post by Dynamicp:
irnnr (05-12-2023), stjoh (05-12-2023), user 6290283 (05-12-2023)
Old 08-03-2023, 07:06 PM
  #102
N2oPANAMERA
4th Gear
N2oPANAMERA's Avatar
Default Out of curiosity...
I'm curious...
Why is it exactly that the Panamera doesn't count?
EDIT: Also, nice write up!
-BB @ Apogee UHP
Old 09-14-2023, 07:36 PM
  #103
vvadim66
4th Gear
vvadim66's Avatar
Hi Everyone.
We are try to repair PDK but not able to pull rear cover off, even with the tool.
Any tricks? Anything else should be removed? (not only bolts).
Any inputs appreciated.
Thank you.
Old 11-09-2023, 05:16 PM
  #104
Daugaard
8th Gear
Daugaard's Avatar
Regarding the bearings for the PDK.
The dimensions are: input shaft: 40x80x20/16
Output: 33x80x20/16
The input bearing is easy to find in the size 40x80x20 and here the turned-down edge of 16 can be easily worked by an experienced machinist.
The output bearing is the hardest to find. Here I have found the bearing for a toyota land cruiser gearbox measuring 32x80x20 and had the 16 mm edge machined and the inner ring ground to 33 mm.
I made the first pdk with these bearings over a year ago and just made another one and it works perfectly.
Daugaard
The following 2 users liked this post by Daugaard:
jbaker136 (11-09-2023), myltz400 (11-30-2023)
Old 11-28-2023, 10:59 PM
  #105
jerrysmalley
jerrysmalley's Avatar
Default Pdk failure
how does one get ahold of T Design?
Quick Reply: Repairing my PDK Gearbox Experience & Guide
