New Vendor Intro: Heavy Knobs
Old Apr 14, 2021 | 11:24 PM
  #61
DesmoSD's Avatar
DesmoSD
Received my Heavy **** weights. They have some nice weight to them. I can’t wait to install them and feel the difference. Thanks Asim.
Old Apr 14, 2021 | 11:40 PM
  #62
Hootsama's Avatar
Hootsama
Looking forward to the real world reviews! I'm almost certain to buy this. I haven't found another **** I like better that doesn't require changing the interior trim, at least for reasonable investment.
Old Apr 15, 2021 | 12:39 AM
  #63
Upscale Audio's Avatar
Upscale Audio
Got mine. Awaiting updated instructions. I don't want to do any more dissembling than I need to.
Old Apr 15, 2021 | 12:58 AM
  #64
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
No other updated instructions than what was included. I can make the link to the PDF available as well.
There are two options:
You can very easily slide all 4 inserts in without removing the shift boot - TBH that could be done in as little as 5 minutes.
If you want to be able to remove the inserts, you gotta pull the boot - again, even this is very easy to do and I photographed every single step in (I hope, a lot of) detail.
Old Apr 15, 2021 | 03:05 AM
  #65
turbo_jimbo's Avatar
turbo_jimbo
Put me on the list, please.
Old Apr 15, 2021 | 01:28 PM
  #66
mpath's Avatar
mpath
Originally Posted by HeavyKnobs
Everyone should have received or be receiving their first delivery by now.
As a reminder, I've already got 16 folks on the interested list for the second batch, which I'm capping at 20 before restocking again.
Please me to the list also.
Old Apr 15, 2021 | 01:43 PM
  #67
ShaunPerry's Avatar
ShaunPerry
Thanks for sending me the correct tracking number. Don't know how PayPal screwed that one up. I went outside to the mailbox and it was in fact there. Will be installing this weekend. Thanks Asim!
Old Apr 15, 2021 | 02:24 PM
  #68
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
added.
2nd batch looking to be ready sometime mid-next week.
Old Apr 15, 2021 | 02:41 PM
  #69
bgoetz's Avatar
bgoetz
Received mine, well packaged with super detailed instructions. Hope to install tonight and will update after putting it to good use!
Old Apr 16, 2021 | 02:22 AM
  #70
DesmoSD's Avatar
DesmoSD
@HeavyKnobs Did you test them out without the tape? I’m trying to determine if the tape is needed or an alternative option?
Old Apr 16, 2021 | 11:00 AM
  #71
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
Great question - I have tested and learned the following:
- For the lower 3 pieces, I generally found that they fit snug enough on their own. Naturally, I had to account for some small amount of casting variation and the potential of the cavities having minute differences.
- The upper piece had to be slightly smaller than the cavity, because the three prongs need room inwards to flex when the cap is being attached. Therefore this piece has a bit of room around it to move once reassembled, hence the tape approach.
- If you are using installation method two, you can easily test out whether tape is needed by installing the weights while the shift **** assembly is off the rod and shaking it - if there's any movement you'll know.
- Overall though - I still recommend putting something between the metal and plastic - because there's resonance there and I've now found by no accident in taking apart my center console at least 10 times that plastic on plastic or metal on plastic should have something put in between to dampen vibrations.
What I am doing:
- The v1 included tape, but am exploring if a double sided strip of tape is better to include - it would also look slightly better.
- Thinking about finishing the inserts in a rubberized coating - but I'd hate to lose the brass finish, which actually in later iterations will be fully polished
- The much more costly approach, but with enough feedback on these potentially altering the shape of the parts/molds to reduce that variability
In any case - I do recommend placing something between the metal and plastic point of contacts.
Old Apr 16, 2021 | 11:16 AM
  #72
Quixotic1's Avatar
Quixotic1
Old Apr 16, 2021 | 11:22 AM
  #73
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
done.
As a quick snapshot - here's how that list is looking for next week's batch:
1. Silvertoy
2. carmanah1965
3. KTM
4. Jonny-Nine11
5. JoshGordon
6. Elonash
7. RecruiterBruno
8. DavidBarry
9. Discomonkey
10. VT Blue
11. Sporty
12. MissileFlyer
13. Bomba
14. Theandycandy
15. ryanbkj
16. dudleyuqa331
17. mpath
18. turbojimbo
19. Quickxotic1
20. RyansRebel
Old Apr 16, 2021 | 12:51 PM
  #74
DesmoSD's Avatar
DesmoSD
What I am doing:
Thanks for following up. I’m wondering if a coat of plastidip clear might be a cleaner alternative. This is their info. I figured this would factor in the minute distance from the mold.
  • Protects coated items against acids, abrasion, corrosion, impact, salts, moisture and weathering
  • Provided non-slip, comfortable and controlled grip
  • Solvent based air dry synthetic rubber coating
Old Apr 16, 2021 | 02:08 PM
  #75
Sporty's Avatar
Sporty
yes that could work ,or just fill the cavity with some clear silicone. I'd assume that would fill any voids and also hold in place a bit better
