New Vendor Intro: Heavy Knobs
Old Apr 8, 2021 | 05:49 PM
  #31
DesmoSD's Avatar
DesmoSD
Originally Posted by David Berry
Can I insert the weights without removing the boot?
I was able to remove the crappy plastic cap/shift pattern and expose the 2 torex screws. I suppose I could remove screws and remove shifter?
If it is that easy, count me in!
What did you use the remove the plastic cap? The plastic interior tools? I'm going to try this method.
http://billswebspace.com/Porsche987ShortShiftDIYNOTE:Several forum members were nice enough to point out that the shift **** can be removed in one piece, I was following someone else’s guide to remove the **** and didn’t think twice about it. Several good comments and pictures on this forum thread to replace below step highlighted in RED in order to remove shift ****/boot in one piece. In summary, you can skip the below step and just pull straight up on the **** AFTER rotating the boot as illustrated in the next step.
Next, I used a small pick to remove the shifter cap by carefully prying up to release clips. Two small screws are removed using a T9 Torx driver (I actually did not have a driver that small so I had to make do with a multi-tool). After the two small screws are removed the rear shifter piece can be removed by pulling back, up, and out:
Old Apr 8, 2021 | 06:11 PM
  #32
texass4's Avatar
texass4
At the risk of being Mr. Wet Blanket, and I do apologize in advance though I have to ask because I'm somewhat interested, $115? For weights?
Old Apr 8, 2021 | 07:04 PM
  #33
David Berry's Avatar
David Berry
I believe it will change the joyful experience of the Porsche six speed into a new type of Nirvana!!!
Old Apr 8, 2021 | 07:14 PM
  #34
David Berry
I used two very small flathead screwdrivers. Put the smallest
blade opposite the 6.
Had to really jam it down at 45 degrees and pried very gently upwards. When the cap started to separate, I put the second driver in ant it came out easily.
The shift cap was in terrible shape, so I am attempting to paint it silver, guards red shift pattern.
Old Apr 8, 2021 | 09:27 PM
  #35
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
You're correct. Four unique weights designed to fit inside the shift ****, individually cast out of brass.
If anyone's thinking it - simply adding "weight" to the rod won't work because you need to be able to add mass at the top of the ****, rather than the base.
Old Apr 8, 2021 | 09:38 PM
  #36
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
This method will make it possible for 3/4 of the weights to be inserted. The fourth however, lives under the plastic edge of the two torx screws that are removed, requiring the disassembly which is still easy.
Fear not however - I'll post updated instructions prior to everyone getting their sets.
Old Apr 8, 2021 | 09:42 PM
  #37
Sporty's Avatar
Sporty
Come on, if your complaining about $115 for a specifically engineered product for a Porsche then maybe you should not be driving one. This guy went to a lot of trouble to develop this and we should be appreciative.
Old Apr 8, 2021 | 10:44 PM
  #38
texass4's Avatar
texass4
I’m not complaining, nor did I mean any disrespect. It just seemed like a lot for what it is.
Old Apr 9, 2021 | 01:30 AM
  #39
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
Hey, I get it.
I've been on this board since 2005 and owned quite a few Porsches - I've seen all the vendors, gone through all the parts and done no shortage of mods.
At the end of the day there are a few things I set out to do:
1) Solve a problem that everyone was experiencing but where no one had sought to seek out the root cause
2) Design a solution that was inherently unique and got to the core of the problem - in this case the feel of shift *****, but that most people did not want to go the aftermarket route for
3) Build something that I designed from the ground up myself, and produced in the United States. No outsourcing, no cost cutting, no mass volume here.
4) Produce it at a price point that was a no brainer for the value it delivered - and I stand by this. My material and manufacturing costs may fluctuate, but I'm confident that most people on here will be able to afford $115 or so for a product that does so much in so little. I'm sure of that - almost 50k of driving my 911 and spending 13 years on this forum, I have enough data points to justify this. Oh, and I make stuff for a living, so maybe that helps.
Old Apr 9, 2021 | 02:01 AM
  #40
Recruiter_Bruno's Avatar
Recruiter_Bruno
Originally Posted by HeavyKnobs
Hey, I get it.
Well put! I hear you and applaud people like you and shops that earn their living making parts that are better for our car! Whether you track or show or just want to turn wrenches then we need entrepreneurs like this to look for improvements. So thank you and thanks to others like Emc2, Function First, Rennline, Suncoast.... Other than my family and close friends (of course) , my car and the extensive community of local friends I've made around as a result of owning or loving a Porsche this has been an amazing distraction over what is going on in the world. So I'm totally fine with $115.
Old Apr 9, 2021 | 06:34 PM
  #41
speedracerf4i's Avatar
speedracerf4i
I understand you. Just put 4 oz (112 g additional weight) of tungsten putty neatly into the same empty spaces for ($8 per oz) to achieve the same outcome. The putty is really easy to work with into the space and has the same density as lead (non toxic). Brass has density of 8.73 g/cm3 and tungsten putty is 10 g/cm3. Pure tungsten is even denser at 17.3 g/cm3. Pine Derby crowds and the fishing community have been using this heavy putty for years. I didn't want to comment earlier out of respect for the new vendor, but now I do see the need to share the info as $115 may still be out of comfort for a lot of folks. Just consider this as a "bush mod" if you want, but do support the OP if you have the means. I have to say that the OP does have a very nice looking product and took the initiative to invest and invent. Kudos to him.
Old Apr 9, 2021 | 07:24 PM
  #42
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
^ there are always alternatives much more in the DIY realm of things. And I respect that.
You can remove your mufflers, drop them off at a shop, instruct them what to weld, bring the muffler home and then install it - or you can call up Fister and do a core exchange without the manual effort. You might save maybe 30% doing it yourself, but for many of us with the fortune of driving these cars, time is precious.
I've also tested different putties, metal powders, metal powder infused plastics, and at the end of the day this was the simplest plug and play solution worth doing - but really, valuable at the end of the day for those willing to buy the product. With any product development there has to be a balance of how much value is delivered to the end user and the amount of effort invested to bring that thing to fruition.
For most who have not taken these ***** apart, there are lots of nooks and crannies inside where if you stick a putty or paste inside, will make it a PITA to remove/scrape out. Most folks with beautiful carbon/leather/wood/alcantara ***** probably don't want to risk getting goop anywhere near those surfaces, which is where Heavy ***** makes it brainless to use.
But to reiterate how much time and effort went into this process, the cost of purchasing all the different iterations of Porsche ***** and assessing what works and what doesn't, testing different manufacturing methods, and not to mention having spun up a reliable process to cast these out of metal... below is just a snapshot of some of that effort:
At the end of the day - I love constructive input from folks and that's why I'm happy to also be engaged in this dialogue.
Cheers!
Old Apr 9, 2021 | 08:45 PM
  #43
Sporty's Avatar
Sporty
If you are driving a 997 and are that strapped, sell it now they are going for a premium. By the time I find out where i can get this stuff, shape it to conform ... I am way past 115$.
Old Apr 10, 2021 | 04:42 PM
  #44
HeavyKnobs's Avatar
HeavyKnobs
Former Vendor
Off to the races!
Old Apr 11, 2021 | 10:17 AM
  #45
rtl5009's Avatar
rtl5009
I’m so jealous of your seats.
