AWD to RWD on .1 Turbo
Can I pull both front axles and then re-install outer CV stubs to essentially convert to "RWD" without any issues? Will leave front diff and intermediate shaft in place. FWIW, this is not a track car.
Check this thread. Answers your questions. The easiest way is to remove the center driveshaft and leave everything else attached.
https://www.6speedonline.com/forums/...rbo-beast.html
Sigh. The naturally aspirated 997.1 and the 997.1 turbo dont have the same awd system. The 997 NA cars have the simpler system while the turbo has the electronically controlled diff and as far as i know no one has managed tk make it rwd.
Former Vendor
See this thread, post #117.
Yes they have. 9ff, a German company sells a control unit that connects to front diff wiring loom instead of the diff, imitating it's operation. So everything mechanical can be removed.
BTW, you can link directly to a specific post by clicking th post number and copying the link. E.g link to post 117
https://rennlist.com/forums/997-foru...l#post16418979
997ajk (03-29-2021)
