Note to Porsche classic - 997 PCCM plus request
#361
Question regarding the microphone: I thought the the new PCCM+ had an internal microphone (the small notch cutout on the top left of the face of the unit) and if that's the case, what is the point of running an external mic? Someone posted a link the other week with an aftermarket mic that can be mounted in the factory location on the top of the steering colum, but is an external mic placed there really that much closer to you and how much better does it sound? I don't talk on my phone much, especially in my 911, so if there is an internal mic on the new PCCM+ that doesn't require the included external mic, I'm inclined to just use the internal mic. Does anyone happen to know if that's possible?
#362
#363
#364
Hopefully, the new one it comes with is designed to be placed in the original position, behind the wheel under the cover. I guess we'll find out once someone posts notes and photos after their install. I'm holding off on buying decisions until after we hear from some early adopters about the mic, if there's a working adapter to gain wireless CarPlay, what kind of multi adapter might be available to support a backup camera, etc etc etc.
#366
Just got an email from Suncoast advertising the PCCM for the 997 -- they are taking names for a "waitlist" and expect delivery March 2023 "or earlier."
#368
The back story is that I designed it half a year ago - as I have trouble-shooted almost all android pcm problems (front/rear cams, radio antenna, canBus etc etc) for the first gen (no button) android 997/987 pcm.
Given this I was presented the oppournity to design a with-buttons PCM, so I did exactly that studying the g1 android pcm, the oem 997.1 pcm 2.0, and the 996 pccm+.
The delay issues is due is for me and the reSeller trying to find certain workarounds - as the mold company ignored key elements of the design (ie. making enough room for larger dials as an example) - and we're wasting time trying to find shorter, stubbier dials that fit the limited space we have to work with (while not going into custom fabrication) in efforts to keep things looking/blending in as oem as possible. All this will be fixed from ground up via the next mold / iteration of the pcm, but that wont be until another year if not 2.
The other issue is trying to get that volcano grey 99% match.
We're trying our best to make it perfect (or as oem as possible) out of the box (for an aftermarket device).
#369
I have to see if they are using the standard android radio rear harness pin setup or not on the rear of the unit. If so there are two different 2 and 3 usb input harnesses that plug into a standard android radio. They may fit into the porsche 997 pccm+ as it is essentially a Chinese android radio. Now even if the harnesses fit, there is no guarantee that the USB input jacks will receive any power or work, as the porsche OS skin very likely has disabled them.
But the exact same thing may apply in plugging in a standard android camera harness complete with reverse trigger cable into the back of the pccm+ , if not disabled potentially those features can be unlocked.
It does looks like they are using the standard android harness for the external mic jack, from what I see in the photos.
#370
#371
The big question of course is what would sound better — internal mic, included mic on top of the steering column, or Enfig in the factory location. That’s a lot less critical in a 911; in my Boxster, microphone quality is the difference between usable, and totally useless because of the wind noise.
Mind you, while running up a mountain road with the top down, I’m not inclined to pick up the phone anyway. But I could make a similar argument about having music on, when I prefer listening to that flat six behind me
#372
#374
There is a connector on the backside of the PCCM+ unit for the plugs I linked.
But that is no guarantee it will function with the firmware settings of the PCCM+.
But the Alieexpress plugs are cheap, so I guess it’s worth a shot.
PowerFlower (12-11-2022)
#375
i have a few spares @ home with 2 usb inputs - 20 pin
there is also a standard 6 pin harness that supports - BACKUP CAM rca, FRONT cam rca, reverse Trigger input, power cable (for cameras), ground cable (for cameras). It looks like it will fit in the pccm+, whether it will actually work... who will be the first to test?
