Show your 997 Upgraded Steering Wheel
Old 08-31-2021, 04:19 PM
  #151
TerrestrialFlyte
TerrestrialFlyte's Avatar
Originally Posted by Petza914
LOL
Believe me, you actually don't want to do that ...
You're probably right. Ignorance is bliss.
Arin21 (09-01-2021)
Old 08-31-2021, 05:08 PM
  #152
Khloesdad
Khloesdad's Avatar
This is funny. When I post an issue for the forums help, I usually include Petes name because its more or less directed to him anyway and yes he'll kindly chime in with the correct answer when he catches it.
The following 3 users liked this post by Khloesdad:
Arin21 (09-01-2021), Petza914 (09-01-2021), TerrestrialFlyte (09-02-2021)
Old 09-01-2021, 01:24 AM
  #153
Arin21
Arin21's Avatar
You are the man!!!
I was looking into what could be wrong; Figured some sort of sensor had gone bad.... Appreciate the help
Your oil pressure looks really high at idle for an oil temp of 200 or so and a normal water temp. I'm guessing your oil pressure sender has gone bad and is reading a couple numbers high all the time. Should obviously show zero when the engine isn't running. If it shows anything else, like 1.5 or 2, time for a new sender. If so, you'll need a ratchet and crowsfoot wrench.
Old 09-01-2021, 01:49 AM
  #154
Petza914
Petza914's Avatar
Received 6,457 Likes on 4,116 Posts
Originally Posted by Arin21
You are the man!!!
So, I'm assuming when you tested it, it read higher than zero with the engine off?
Glad to help!
Old 09-01-2021, 08:45 AM
  #155
Carreralicious
Carreralicious's Avatar
I just checked mine after seeing this, and with engine off and key turned to right, oil pressure gauge showed .5. Is my sender bad cause it is not at zero? And is there any consequence if it is bad? I mean, the only thing is that you’ll have incorrect pressure readings, right?
Old 09-01-2021, 08:58 AM
  #156
Petza914
Petza914's Avatar
Yep, and it will make the gauge always read .5 higher than the actual oil pressure.
Old 09-01-2021, 10:29 AM
  #157
Carreralicious
Thanks. I just checked again and it was now at zero. Guess there was some residual pressure there that settled down.
Old 09-01-2021, 10:35 AM
  #158
Petza914
Petza914's Avatar
Maybe. Just keep an eye on it. I probably wouldn't change it for that little amount. They start reading 1.5-2 high when they really fail.
The following 2 users liked this post by Petza914:
Carreralicious (09-01-2021), mmoran33 (11-22-2021)
Old 09-09-2021, 06:55 PM
  #159
sda
sda's Avatar
I thought I had already posted this when it was completed a few months back.
The following 4 users liked this post by sda:
Darkboyz68 (12-21-2021), james6speed (09-09-2021), myw (09-28-2021), TerrestrialFlyte (09-09-2021)
Old 09-09-2021, 07:24 PM
  #160
frybear
frybear's Avatar
Looks good! I actually have a similar style steering wheel, no MF buttons that I'm removing and probably going to sell. I like it but it feels too big for me.
james6speed (09-10-2021)
Old 09-10-2021, 12:06 PM
  #161
mm31
4th Gear
mm31's Avatar
Looks fantastic !
Old 09-11-2021, 07:54 AM
  #162
villeman
3rd Gear
villeman's Avatar
Looks fantastic! Was it a difficult install? Do all the buttons work as intended?
Old 09-21-2021, 03:05 PM
  #163
Bwoy1981
Bwoy1981's Avatar
So I just picked up this wheel (991.347.803.47.A34) to put in my 2005 997.1 manual/ base with no multifunction features.
I'm looking into the airbags, but there is one for the 997 (2010 - 2012) generation and one for the 991 (2012 - 2016) that look the same on Suncoast Porsche website.
https://www.suncoastparts.com/product/997G2AIRBAG.html
https://www.suncoastparts.com/product/991G1AIRBAG.html
I'm guessing the correct one will be the 991 airbag to go with the wheel but would i need the steering wheel module? Any insight would be great.
Old 09-21-2021, 03:18 PM
  #164
arscottp
arscottp's Avatar
90% sure either 997.2 or 991.1 airbag will work, no new module
Old 09-21-2021, 03:22 PM
  #165
cakM3
cakM3's Avatar
You will need a 997.2 airbag for this steering wheel. Like this one...
Quick Reply: Show your 997 Upgraded Steering Wheel
