Cheap Android Head Unit Review!
#1006
Thanks so much Matt!
I think I've got it now.
I will look in the morning for a black/blue wire behind the fuse box near the driver's feet and then plan to splice the #3 wire from the main 16-pin connector (it is brown on my unit) to that black/blue cable.
Not sure I have an unused wire with the attached pin that will fit into the small 'F-Plug' - I'm guessing the pins on the unused harness are too large - do I need F2 (NC) for anything? It's not connected to anything. I will go to an auto store if I can't find an unused pin.
As for the rest, your image is perfect, I just got to figure out the best way to route the cable to the rear bumper - was thinking under the side trim on the center console, but the driver side under the carpet/trunk release buttons is probably as easy.
Any other advice on routing, best way to get to the cam mounting point which will be just above the license plate in the center?
Oh, and what gauge wire should I use for the splice on the trigger wire to the black/blue? EDIT: thanks @scadams for letting me know it's 16 gauge![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks again, will report back how it all goes.
#1007
I ran the camera wire to the left along with the license plate light wiring, thru the tail light grommet on the driver side into the cabin, then along the driver side floor/trim - just tucked it under the trim or carpet using a trim tool.
The reverse trigger wire is 18ga. it's a very low current wire, even 20/22ga is sufficient, but 18 makes it easy to use the 18-22 gauge quick disconnects on both ends. It also matches the wire you'll be tapping into
#1008
Granted I have a 987.1, but is this still the best option other than the PCCM plus from Porsche? I want a OEM look, with Carplay, and a backup camera would be a nice addition. However I am inexperienced in dealing with this stuff, and reading through the forums the potential problems seem concerning. I have the BOSE system.
#1009
There will be another version, sold outside of aliExpress (the faceplate wont be available on the cheap units) that will sell for slightly more - it will have the 2024 cpu's and further android hardware / software changes.
But will have a faceplate + dials (fully light up) - that will have an even better color match + a design that will look practically oem. Alongside install manual/video + mounting hardware to ensure perfect fitment. It will be approx a year before this happens.
Is this one still on the way? If there's going to be a better version coming out in early 2024, I might just wait. I only have another 2 months driving before winter comes anyways. Thanks!
#1010
Dang it...I ordered 16 guage, overkill but it will work just fine even if I have to solder if the quick connects I have are too large for the 18 gauge.
Thanks for the guide on where you put the wiring.
Can't wait to have this installed and then I need to go to a local P-Car shop to have them fix my heated seats which stopped working after a main battery change - I read this is a common problem. I think some of the AutoZone type stores have readers only so unlikely that they could enable the heated seats?
#1011
#1012
@c1n3ma - it's actually a lot easier than you would think. If you don't need or care to add a reverse backup camera, even easier.
There's really helpful people on here, and lots of images - remember the units have improved since the first folks started installing these 3 years ago.
I also have the BOSE system in my 987.1 Boxster S, and it's literally 3 wires to connect and plug in the factory fiber optic cable into the provided box.
I wanted a backup cam, so a little more work, but I'm planning on giving the car to my daughter so it lowers the chances of dings.
Compared to the the OEM PCM options, there's no comparison - many in this thread will attest to that. And for a tiny fraction of the price of OEM, especially if you have them install it.
#1013
#1014
Quick question regarding some of the units. I've seen focus on matching the grey color/aesthetic of the OEM PCM. What about the button backlighting? Do any units match the OEM button backlight color? Not trying to have severely mismatched colors
#1015
#1017
the button backlight is configurable in any RGB color, and on some models, intensity as well
#1018
#1019
I'll take it for a cabin air filter change (or something cheap) and casually mention the heated seats stopped working after battery change - it's literally no skin off the tech's nose to re-enable the heated seats.
TBH - they should do this for free as it's something that shouldn't happen - changing the battery shouldn't cause the car to forget it has heated seats!
#1020
Wow, looks like the Qualcomm version is almost twice the price of a 4GB Ram Owtosin unit. ($330 vs $490+$80 shipping). Is it really worth the difference? Also going back I'm still curious if they're going to make a better revision for 2024 or not.
