Topgear center muffler bypass for 997.2
#95
Price is right for sure but those 180 bends look a bit too much like the stock muffler it replaces for my likes. Compare to the mostly straight Sharkwerks pipes (along with a cut up stock muffler) below. I also have to admit I'm skeptical about these discount bypass systems that keep popping up. Someone posted recently about installing the discount Billy Boat pipes. Required several people to "manhandle" it to finally get it in place.
A matter of personal taste I suppose but I don't really care for exhaust parts (or any parts for that matter) that are so poorly designed or cheaply built that they need manhandling and bending for installment. I had my Sharkwerks pipes replaced as part of a recent rear end collision repair. I asked the body shop manager about the Sharkwerk pipes fitment. "Bolted right on like stock parts" he said.
#96
Premium Sponsor
When replacing exhaust pieces, you need to first loosen every bolt in the entire system. After replacing part, then tighten every bolt in the system. Followed this recommended procedure with my Billy Boat bypass and had no problems. I looked at shop drawings of Sharkwerks and BillyBoat product before buying. Only difference I saw was $200 increased price which I assume was a Cali tax.
Dan Kennedy
SharkWerks: www.sharkwerks.com
Northern California's Porsche Performance, & authorized Evolution Motorsports, TechArt, HRE and Tubi, Cargraphic dealer and installation center
Phone: 510-651-0300
Email: dan@sharkwerks.com
SharkWerks' Latest Updates on Twitter
Dan Kennedy
Phone: 510-651-0300
#98
The Billy Boat system has no exhaust mounts, so it's much less expensive to manufacturer (we have to laser cut stainless steel plate, bend it on a brake, weld it to the pipe, then weld a bolt to it for a stud/fastener, include custom lasercut stainless steel plates to sandwich it in place, and extra hardware to fasten it to the car. Then we also include OEM gaskets (a lot of companies don't include OEM parts), all new nuts/studs/bolts for the parts replaced (I'm not sure what BB includes), and if you call us we will answer the phone (!), and everyone you talk to here has installed this product and is very familiar with it because we only work on Porsches and owned this car. It also fits better (according to most people we talk to), even with PSE. Whether that's worth $200 or not, I can't say, but they're not 100% the same.
Dartmouth (06-19-2021)
#99
Premium Sponsor
Respectfully disagree. My BB center muffler delete had two exhaust mounts located where the factory center muffler met the side mufflers. It is the OEM factory location….not a new custom made location. So, it had exhaust mounts but in a different location than the Sharkwerks product. Like I recommended before, potential buyers should compare shop drawings of all potential products before making a purchase decision. I will defer to the readers whether they believe gaskets,nuts, bolts and studs are worth the extra $200 price. I had no issues installing the BB product when following correct install procedure which should be followed for all center muffler delete products (BB, Sharkwerks, Fabspeed, Topgear,etc.).
https://www.bbexhaust.com/shop/porsc...pes-fpor-2535/
I could remove the mounting brackets from our exhaust and sell it for $200 less to Rennlist members, but I feel like the OEM exhaust has it, so any replacement should as well.
FYI I am referring to the way the OEM exhaust has straps that allow it to "hang" on the engine cradle. The current photos in the BB product show no support bracket there.
The fitment issue refers *especially* to cars with PSE as they have less clearance on the side mufflers. There are a few threads saying the BB did not fit with PSE or rubbed. Again, maybe they changed it.
BB removes #12 from this diagram:
They do not replace the hangers. Maybe it won't hurt, maybe it will. And it does cost a lot to add them, which they likely did to save money. We'll keep building them this way because we think it's the best way, even if it's not the cheapest.
#100
Okay, that's new then. The BB center used to have no mounting brackets at all, and their photos still show that it does not. Our system does use the original location, not a custom made location.
#101
#102
Had my TopGear bypass installed. My impressions so far:
- the bolts that come with it are indeed too big for the stock cats. Replaced with M8 1.25x30mm flange nuts in stainless.
- noise with stock side mufflers is almost unchanged from stock…I knew this going into it.
- no rattles or vibrations; seems smoother than stock where I had a slight rattle noise when reversing.
This is for a 2011 C2S PDK.
#103
No fitting issue with Milltek, identical to the Sharwerks (shape, quality).
With the bypass, you restore the design of the 997.1 exhaust without the speed-related cutoff,
the only difference is the cats in the collector on the 997.2 and in the cross on the 997.1.
Porsche designed the center back-box only for noise regulation law, not for performance.
Porsche doesn't use the X-pipe design, only the bypass (cross) design, why?
Because from a mechanical point of view, the gas mixture of the 2 banks is not optimal on the Flat6, not like on a V8.
For the quality of the noise, I don't know what is the best configuration.
#104
Here is my 2011 997.2 with the TopGear UK valved exhaust system and x-cross center muffler bypass.
#105
you've spammed every exhaust thread. You aren't a paid member here either. I'm sure you are monetizing this somehow. Hopefully the mods will move this out.
