Loudness of 997.2 PSE
I recently traded in a 2015 Boxster S manual equipped with PSE, for a 2012 911 GTS manual likewise equipped with PSE. On the Boxster the PSE was quite loud (maybe enhanced by the intake sounds since the engine is right behind you) in the GTS, even with the top down, the PDE is only a bit louder than non-PSE and way way quieter than the Boxster (even taking into account rear engine location). So my question is if this is normal, or maybe the valves on the PSE are not opening fully. I have a service appointment next week and I am going to mention this, but I will appreciate input from the members. Thanks
I've a .2 PSE and like you, I find the differences between on/off to be very subtle - and I know if I paid $2,800 for PSE (when new), I'd have been seriously disappointed.
Yet... to a colleague of mine (when listening to my car), he thinks the differences are significant. He literally thinks it sounds way louder with PSE on.
So I think there's real perceptual differences from person-to-person when it comes to how these things sound.
My wife and I thought the GTS, even with PSE, was too quiet, but I came out of a 996GT3 with Cargraphic mufflers. I installed a SW center muffler delete pipe. Woke things right up! Big difference. When I crank it on in the garage even with the garage door open, the exhaust sounds good. When I open up the PSE, even better.
I recently bought a C4S with PSE. It is a bit louder, maybe 20%, vs non-PSE. I also own a C2S with Fister mufflers and SW bypass pipes. The latter is much, much more aggressive. I can't say what the Fister cans w/o bypass pipes would sound like, but if they are even 50% of the combo sound, I would opt for that over PSE.
The C4S with PSE just isn't that aggressive; it needs more...something
We had a Boxster S with PSE, and it sounded pretty good with the top down. My wife's 991.1 Cab C2S with PSE is much louder however.
Just unplug the vacuum actuator in engine bay (located on top right as you face engine). Takes 10 seconds, no tools required, no cel, and it's free. That will get flaps to be totally open with no modulation from ecu which attempts to reduce noise in accordance to noise regulations. If you get sick of it, plug it back in. By the way, make sure flaps open and close with press of pse button as they are known to fail due to many reasons.
If you insist for more noise, I'd recommend sharkwerks center bypass but keep in mind, you will loose a bit of the buttery refinement your car has as is from factory.
good luck
good luck
^^^ I got the chance to hear a GTS with PSE before and after X pipes (center muffler delete) in person, and it was a night and day difference (closed to closed as well as open to open). Similar to the 997.2 non-PSE with a Fister Sports Exhaust before and after a center muffler delete x-pipe, if you do not delete/bypass the center muffler, the sound results from the side muffler partial bypass is muted significantly. There are some youtube before/after of both. sound-wise, it seems like the PSE open and the Fister have similar noise characteristics, so before and after X pipes on either one should give you a general idea.
Last edited by jamesinger; 04-12-2018 at 03:30 PM. Reason: typo...as usual b/c iphone.
