997S Auction Car - Track Build
#32
Harbor Freight has a cheepo knock off one man brake bleeder that hooks up to your compressor for $33ish and works well.
Under the tarp???? Z3 but the headlight bulges say no. But........I my guess is an air cooled 911 without a tail under a cover that was for a 911 WITH a tail.
#35
I’m betting it’s a metallic green 77 911 with a duck. You know, like the one he says he owns in the second sentence of this thread.
#36
I got this one, mostly because I had Walmart gift cards
https://www.walmart.com/ip/Vacuum-Br...ruck/100730605
Got headers and cats from topgearuk.com. Decent quality and good prices. Sounds good at idle and driveway revving
Installed - I want to re-do the piping from the mufflers to the cats and then the mufflers to a center exit
Started stripping the interior, may not look like much but this was a ton of work
These are the SPC adjustable control arms I mentioned before
#39
More! More!
Great thread, How do you know what components to find/buy? just P-car experience?
Roll bar i presume? whose seats u using? and harness?
Keepem coming, mike
Keepem coming, mike
#40
More coming on the interior later.
Holes in the front bumper filled with Fusor and skimmed over with SEM bumper bite.
Quarter prepped with Dyna-glass
Changed the oil with Vavoline ZR1 - Racing oil so you know it's good. It's normally $9/quart, but it was on clearance at Autozone for $1/quart. Takes 9.5 quarts. No metal or anything concerning in the old oil.
More interior stripping. Stripped both doors down. Rear windows pulled.
Wires prepped and sound deaden tar removed
Sun roof removed
Dash removed
Window seals removed. These were riveted on
19" parts received from BBS for my e88's
Test fit
I dropped all the misc loose parts off at the painter early. Got a few pics from him. I plan to take the shell next weekend
Color is Porsche M9A that came on 2017 Panamera called Crayon and 2018 GT3 called Chalk.
The updates should get a little more excited moving forward
#42
I'll keep on an eye it, but i'm in Texas so it'll be okay with regular oil changes.
Few more painted parts. Don't mind the grass
Numeric Racing shifter came in
Cleaned up the tar areas
Backed it out of the driveway and turned it around. That was fun.
And loaded it up on a uhaul to take to paint
#45
