High mileage 996 TT?
#361
#362
I am jaded now. I want to see 1,000,000.
Great job T2.
Great job T2.
#363
kmagnuss (08-12-2019)
#365
#369
T2 are you located in RI? i thought i remember seeing that in an old post. If so, do you ever make it to any events? I'd love to see your car in person sometime! I'm fascinated by it.
#370
318,000+ miles here on my 2003 996 Turbo X50 - bone stock minus upgraded intercoolers and Baileys DV's. Look up some posts from me this past summer to see what has needed maintenance.
90k miles is just broken in to me. What is he asking for the car, what color combo, what light mods does it have and lastly what were the recent service receipts for??
T2
T2
#371
Did you pin/weld your coolant lines? I am buying an 01 with 26k miles on it and stage 2 AWE upgrades. The pricing is about $50k. I thought this was expensive but I do realize low mileage no accident nicely modified cars can fetch a premium. It's been very well kept by last 3 owners and current owner keeps it parked on a lift in his garage and only drives it in beautiful weather when he has time. I just want to make sure it's worth the ask.
Low miles doesn't equate to less monies now being spent on maintenance. These cars really need to be driven, when they sit, stuff goes bad. I have welded coolant lines, gt2 clutch setup, CSF rads. That alone is like $10k+. Wanna buy mine? 2003 w/ 68k miles and mint.
#372
What else does yours have done to it? This one has a sachs stage 2 clutch and a bunch of other stuff through AWE. I just figured if the coolant lines arent pinned I would pin them and be doing regular maintain when as needed. The car will not be tracked but it wi be driven hard after reaching operating temps when hot. PM me more info on your car.
#373
2003 Porsche 911 Turbo
Black/Black 6 speed 68k miles
3-owner car, locally bought (from neighbor) originally purchased at Champion Porsche in Pompano Beach, FL. Highly Optioned car to include: tufted leather seats, crest in headrests, carbon fiber interior, suede headliner, RED seatbelts. Over $25-30k in recent receipts. All records on hand in binder.
Recent Maintenance:
1. Sachs 2.5 clutch with OEM flywheel (764 PP and sprung 098 disc)
2. GT1 Coolant fittings welded
3. Torque Solutions Engine mounts
4. Torque Solutions Trans mounts
5. OEM gt2 slave cylinder conversion using all OEM parts (new line, slave, clutch master cylinder and gt2 spring assist- transmission drilled/tapped for OEM appearance/function) – Even used a new OEM GT2 power steering reservoir to maintain appearance and to not have used plugged lines
6. CMS billet side diff cover - not installed
7. CSF Aluminum Radiators (3) installed with almost every coolant hose replaced with OEM with all new o-rings and clips. All worm clamps replaced where available *center replaced 8/2019
8. New OEM fuel pump
9. New OEM water pump
10. New Thermostat
11. New OEM drive belt
12. Rebuilt front CV joints/axles
13. New OEM passenger window regulator
14. New 18% Suntek tint all around with lifetime warranty
15. New Weather Tech all weather floor mats
16. New OEM spark plugs
17. 997 coil packs
18. Shift Detent installed in transmission to prevent any possible 2nd gear pop out issues (never experienced; installed as precaution)
19. New battery 3/18
20. Alternator/starter replaced
21. New cam angle sensor
22. New OEM fuel filter
23. New OEM water temp sensor
24. New OEM oil temp sensor
Just installed a new OEM igntion switch in June also.
Car also has the following:
gt2 carbon front bumper - FVD motorsports, made by OE supplier to Porsche
turbo cup rear decklid and 63" carbon cup wing
Forgeline 18x9 and 18x12 wheels
Elephant Racing control arms, dog bones, caster arm, drop links, toe arms.
Numeric Racing shifter and cables
Autometer boost gauge on column
COBB tuner, tuned by Sam @ ByDesign (mafless)
HKS SSQV BOV
4.5" Bell Intercoolers
EB Werks <or> REMUS exhaust
KW v3 coil overs
Built in radar detector in rear mirror
Battery tender hard wired
Porsche Carerra GT OEM key
Rennline Pedals (not installed)
jayi836 (08-14-2019)
#374
I had a scare on my 120k mile 2001. I noticed a knock coming from cld #1. It sounded a lot like a wrist pin or perhaps a rod. But, it ran great. Good oil pressure. No metal in the oil filter. My scare was the thought that I might need a 20k rebuild on a car that was maybe worth only low thirties. I worried that I had just lost a good part of my "investment". After much procrastination I took it to a Porsche Indy. It turned out to be a loose spark plug. After eval and fix the total bill was $918.00. I have never been so happy to pay someone a grand to tighten my spark plug! Still, I worry now that I might loose my entire investment should the car break... I've had 2 previous 996 non-turbos that kicked me to the curb like an angry ex-wife when they suffered catastrophic failure. These worries now in the back of my mind with the 996tt ...it kinda takes away from the fun of driving it. I think I'll sell. craig
#375
HKS SSQV BOV
KW v3 coil overs
HKS SSQV BOV
KW v3 coil overs
