996 Turbo Forum 1999-2005
My car burned today
Old 10-16-2007, 03:37 PM
  #61
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Got an appointment for tomorrow morning... also saw someone made an entry on http://www.mycarstats.com/
Component: STEERING:HYDRAULIC POWER ASSIST SYSTEM
Details: POWER STEERING FLUID VALVE MAKES A NOISE. RESEARCH ON 6SPEEDONLINE.COM AND RENNLIST.COM NOTE THAT THIS WILL FAIL, OVERFILL THE RESERVOIR, AND CAUSE A MAJOR FIRE PERHAPS KILLING ME. PORSCHE HAS UPGRADED THE PART KNOWING OF THIS FAILURE AND HAS A PUBLIC TSB TO THIS EFFECT. *JB
Occurrences: 1 Injuries: 0
Fail Date: 09/20/2007 Deaths: 0
Date added to datbase: 10/8/2007
[FILE] your own complaint on this model car.
Old 10-17-2007, 12:34 PM
  #62
Wachuko
Wachuko's Avatar
Cool
Left the car today at the dealer to go over this... will report back on what they find...
Got this as a loaner:
New Cayman - 5-speed, 955miles...
Old 10-17-2007, 01:35 PM
  #63
jimq
Burgled
jimq's Avatar
I need to take mine in there to get one of those loaners I will have to go see if mine is making a noise tonight !
Old 10-18-2007, 02:12 PM
  #64
Wachuko
Wachuko's Avatar
Well, dealer could not find anything wrong with the car. The sound from the steering pump that I have is normal. So it seems you guys that have had the problem must be hearing some real loud steering pump noises... and they kept mine overnight to listen to it from cold...
On my way to pick up the car now.
Old 10-18-2007, 02:20 PM
  #65
wross996tt
wross996tt's Avatar
Mine was somewhat intermittent, but when it happened, you could hear it. Mine did not have a problem cold...actually after it warmed up...I told the dealer to replace it and handed them a copy of the TSB....they did it under warranty.
Old 10-18-2007, 02:23 PM
  #66
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Old 10-18-2007, 04:36 PM
  #67
T2
T2's Avatar
Thanks LTC - for clarifying it's not the noisy pump but loose connections on certain VIN's that is really the issue
Old 10-18-2007, 07:05 PM
  #68
Kevin
Kevin's Avatar
T2 and others, there are two ISSUES BOTH will cause a failure and possible fire!!
One being the loose hose fitting
2nd being a faulty pressure release valve located inside of the Pump reservoir, as the valve sticks the pressure in the pump circuit goes thru the roof, it blows out the viton seals between the sump reservoir and pump. Once the seal are breached the Petosin squirts all over your cats, and turbochargers..
Similar issue as the hose connection coming loose..
Again two seperate issues...
Old 10-19-2007, 09:31 PM
  #69
dave1200
dave1200's Avatar
Ok guys..
This is what casued the fire. (the notice posted above.)
My Ins co has settled with me on the car. They are prepearing for a lawsuit with PNA. They have the car stored for safe kepping in some sort of vault or something.
I also have my lawyers looking into a posible suit as well.
Ill keep you posted.
Old 10-19-2007, 09:54 PM
  #70
gobble
gobble's Avatar
Why does this only affect 2003 cars?
Who would you sue if the ins company paid you for the car?
Old 10-19-2007, 10:32 PM
  #71
Giovanni
Giovanni's Avatar
Probably Dave is planning on sueing PNA as well.
Old 10-20-2007, 01:52 AM
  #72
gota911
Newbies Hospitality Director
gota911's Avatar
..... or the dealer he bought the car from. It was a pre-owned car and I "think" (not positive) it was also a CPO car. Doesn't sound like the dealer did their due diligence to make sure all outstanding TSB’s applicable to that particular car were resolved.
Old 10-20-2007, 01:55 AM
  #73
gota911
gota911's Avatar
Originally Posted by dave1200
Ok guys..
I'm glad they were able to determine the exact cause. BTW - can you say "free 997 Turbo?"
Old 10-20-2007, 02:47 AM
  #74
1AS
1AS's Avatar
Would you mind sharing details of the settlement? Did you get something approximating your cost, or that number minus extra depreciation, or the actual wholesale value of the car the moment before it caught fire? AS
Old 10-20-2007, 11:14 AM
  #75
shustermeister
shustermeister's Avatar
Ok guys..
From one Charlottean to another, glad that nobody was injured and that you've settled with the ins co.
I think I'd seen your car in my area of Southeast Charlotte/Ballantyne area about a month ago - was that you?
Quick Reply: My car burned today
