996 Turbo Forum 1999-2005
Pinning the lines
Old 06-17-2020 | 08:15 PM
  #106
Mezger Man's Avatar
Mezger Man
Imagine the cost to have a welder do the job. But anything done right to a car will cost you.
Old 06-17-2020 | 08:31 PM
  #107
s65e90's Avatar
s65e90
Figure 10k to pull motor, weld new (better) coolant fittings, change clutch, change all coolant hose and all o-rings on motor and any other incidentals while apart. Essentially a top-end rebuild sort of.
Old 06-17-2020 | 09:29 PM
  #108
Carlo_Carrera's Avatar
Carlo_Carrera
Seven years ago when I had my engine pulled, pipes welded and few other preventative things done the cost was $4500 cash. It was a special deal with the work being done during the dead of winter.
Old 06-17-2020 | 09:32 PM
  #109
manimal's Avatar
manimal
Not to keep beating this horse, but welding isn't going to be that much more expensive than the "proper" pinning procedure outlined in this thread. Most of the cost is in the R&R of the engine + everything else you do while you're in there.
Looking back at my recent invoice of having this all done (@ Vollig in San Diego), I paid 15 hours labor (just under $2k) for the actual welding labor ("DISASSEMBLE COOLANT ASSEMBLIES, REMOVE EXISTING COOLANT FITTINGS, FIT NEW THICKER WELDABLE FITTINGS, WELD FITTINGS. ASSEMBLE COOLANT ASSEMBLIES").
Total bill was over $10k (not including the transmission rebuild) but we did "everything" + I slipped a few upgrades in there (intercoolers, clutch, GT2 slave).
Old 06-17-2020 | 11:14 PM
  #110
k9turbo's Avatar
k9turbo
Originally Posted by s65e90
Another useless thread full of pages of going nowhere. Let's just put the nail in the coffin. Those who say it's not a big deal and argue against it are the ones who most likely don't have them pinned/welded and wish they did.
and yet, here you are.
"nail in the coffin"? as you are the official arbiter and have the final definitive "word"? i think not lol, that's ridiculous.
it's not a BIG DEAL unless they FAIL ( how many of the thousands of 996 turbos have had the coolant lines fail? not many ) or you WANT to proactively have the coolant fittings retroactively re-fitted to answer certain race track requirements.
your analogy reminded me of a Dr Suess book about the sneetches in Whoville. Some had stars on thars, and some did not and some felt bad.
me? i dont give a flying **** about the coolant lines that have performed and functioned as intended for 17 years and 170k miles.
if they ever let "go" they get repaired. meanwhile, the SKY is FALLING.
05 Turbo S (06-18-2020)
Old 06-17-2020 | 11:19 PM
  #111
2fcknfst's Avatar
2fcknfst
My passenger side (rear) cooling hose split, when cool, not under load, and that was enough to get me to pin - upon inspecting the damaged hose, there was zero sign of rubber decomposition/hardening - it simply let go after 15 years.
The sky fell that day...
Old 06-17-2020 | 11:22 PM
  #112
k9turbo's Avatar
k9turbo
i am terribly sorry to hear of that but i can't imagine you taking it "that hard". but it's funny. the only time you ever hear of them failing is on a porsche car forum.
no one ever reports not having problems. it makes for lousy debates.
Old 06-17-2020 | 11:30 PM
  #113
2fcknfst's Avatar
2fcknfst
Yes, it was one of my first posts on a failure - interestingly, it was the day I got the car back from the garage with the new exhaust on.
Coincidence, or conspiracy? ... you decide tonight @ 9...
Old 06-17-2020 | 11:32 PM
  #114
k9turbo's Avatar
k9turbo
same day? not superstitious, but i'd lose that shop on principle alone.
maybe the car knew the the topic had been once again resurrected.
Old 06-17-2020 | 11:33 PM
  #115
2fcknfst's Avatar
2fcknfst
It (the Car) was expressing its distaste for me taking it to a Ford dealer...
k9turbo (06-17-2020)
Old 06-17-2020 | 11:49 PM
  #116
Turbodan's Avatar
Turbodan
Originally Posted by Dock
What wasn't done properly? The glue application?
yes and the choice of glue, which does not seem to last.
Old 06-18-2020 | 12:14 AM
  #117
k9turbo's Avatar
k9turbo
oh but it does - and doesn't. both lol
Old 06-18-2020 | 01:00 AM
  #118
Turbodan's Avatar
Turbodan
if it doesn't then it you can't count on it to does.
Old 06-18-2020 | 01:46 AM
  #119
Dock's Avatar
Dock
It certainly lasts in some (many?) 996 Turbos. Reference k9turbo's car.
There is no data that I know of that indicates that it "was not done properly at factory" on all 996 Turbos.
Old 06-18-2020 | 02:01 AM
  #120
k9turbo's Avatar
k9turbo
most. it has lasted in most of 996 turbo's built. my car is not the outlier.
if 996 turbo coolant fittings failed at a higher rate. there would be more than the same 12 of us here talking about "it" year after year.
other than the occasional, but rare "victim" lol. the internet loves misery.
Dock (06-18-2020)
