NEED 2001 996 TT Transmission
My indy mechanic confirmed my transmission done. 125,000 miles on 2001 996 TT. He checked Porsche supplier in North Carolina but no transmissions available. Any thoughts/ suggestions/ direction appreciated.
Thanks,
Sean Miller
Thanks,
Sean Miller
Sean, right now it is really hard to find good used 996TT gearboxes..
Porsche is providing 997TT gearboxes for the 996TT>>you might search for 997TT.
What is wrong with your gearbox? Is your ring and pinion destroyed..
All the parts are still available to rebuild these boxes..
I have 3 rebuildable gearboxes..
Send me a email or call me
Here is poc of transmission
Here is pic of transmission. Is the clutch fork the silver piece at 3 o'clock in picture?
2001 996 TT TRANSMISSION
[img]blob:https://rennlist.com/49959960-7726-4...d-431b6b83de0f
That is the 2nd cracked bell housing that I have seen this year. One of my customers just got done installing his repaired gearbox this past weekend. Your gearbox can be fixed! Email me..
the silver piece is whats left of the clutch fork rod ear. the rod goes thru and seats into the belhousing. that unit is toast. norspec dismantling in washinton state has a 996tt that they are parting out and its a manual
Yep as Kevin said that can be fixed. I had done it back in the day for a 964 guy. Definitely not the end of the world.
High mileage cars that haven't had a new clutch can wear the throw out bearing fork, throw out bearing, the nylon fork bushings and sticking needle bearings all contribute to the failure. The wear SLOP that accumulates and this is what happens. This is the 2nd failure just like this in 8 weeks. Stock clutch, all stock cars...
Looks like someone already took a stab at “welding” it based on what appear to be globs of melted aluminum. That area would need to be thoroughly cleaned and maybe preheated for any chance at a successful repair.
