Coolant Line Failures- NHTSA
#140
My leak in post #132 is a burst or split upper hose, discovered upon pressure checking.
The discussion I had with the shop was essentially that this glue fitting deal is something I may be best served by dealing with over the winter.
Something does need to be done to those fittings as a long term solution, but for now it looks like I don't have a reason to file with NHTSA.
#141
I'll definitely make sure the dealer reviews the coolant lines on the '07GT3 I'm having a PPI performed on next week! I have an '01 TT with 18,000 miles with no issues. This is a big deal and BS if Porsche doesn't address this issue. Lotus got nailed about 6 months ago for an oil line failure on the Elise and Exige. Investigation turned into a full recall.
#142
Anyone who thinks that a dealership has fixed the problem, please don't kid yourselves. Dealership will repair a popped fitting by installing a replacement casting with fitting... or maybe re-epoxy.
The permanent fix is an after-market solution, so unless your dealership is into modifying cars, I doubt it's going to happen. Good luck even getting them to acknowledge the possibility of existence of the problem. In the mean time, water + Water Wetter please.
I was at, so witnessed first hand... again:
Mosport 2 weeks ago - 1 996 GT3 + 1 997 TT
Tremblant this week - 1 996 GT3 + 1 997 GT3 RS
#143
#144
At Tremblant the 996 GT3 was the coolant hose that feeds the tranny cooler. The hose got cut due to a tie strap breaking so the hose was an innocent victim. Add checking the tie straps on the hoses to be safe on the track. The 997 GT3 RS was a fitting on the top of the engine. He drove to the track but had to have his car towed home.
Thanks for the update.
#145
Daytona Prototype engine. Just a smidgen different.
#146
There was a thread on 6or7 gt3 forum with details for each area in the us ie who, how and cost
#149
Year: 2002
Model: GT2
Mileage: 26,000
Circumstances surrounding failure: May 2013, Turn 3 NHMS (rear end got loose but no spin)
Repair Solution: getting all fittings welded by EPE in Natick, MA
Model: GT2
Mileage: 26,000
