996 Forum 1999-2005
IMS Tensioner Paddle failing?
Old 07-14-2016, 03:36 PM
  #61
AWDGuy
AWDGuy's Avatar
one time use. oem isn't bad at $11/each. you need 24.
if you go with ARP however...
Old 07-14-2016, 04:24 PM
  #62
alpine003
alpine003's Avatar
Originally Posted by AWDGuy
Yeah, even a DIY "refresh" is going to cost a few K. Look up the price of head bolts....yikes
I'm not exactly sure what "your" version of refresh is but Vertex Auto sells a kit for a little over $1300. Not everything is OEM though so might not be apples to apples.
http://www.vertexauto.com/showitem.a...20C4%203.4%20L
Parts List:
Qty Description Part Number
1 Rod Bearing Set (Standard) 99610312162
1 Main Bearing Set (Standard) 99610120510
1 Piston Ring Set 99610305302
12 Connecting Rod Bolts 99610311551
1 Loctite 574 50 ml Tube 00004301000
8 Flywheel Bolts 99907309209
24 Valve Guide (Intake & Exhaust) 99610414501
1 Chain Rail - "U" Shaped 99610516651
2 Chain Rail - Straight 99610517353
2 Chain Rail - Curved 99610517552
1 Engine Gasket Set 98610090500
1 Cylinder Head Gasket 4-6 99610426901
1 Cylinder Head Gasket 1-3 99610427006
24 Valve Stem Seal 99610427006
2 Timing Chain - Intake Cam 99610517053
2 Timing Chain - Exhaust Cam 99610517752
Old 07-14-2016, 04:51 PM
  #63
AWDGuy
AWDGuy's Avatar
Yeah, not apples to apples. some of the gaskets in these kits look like total junk. I never used this one but I used aftermarket gaskets from pelican and was glad I had the OE stuff around for some of then. ...
and you're still missing head bolts, case bolts, lots of bolts missing..lots of gaskets are missing in that list also. You arent going to reuse your water & oil pump gaskets. hope not anyways.
that's a good kit to get you started but don't think that will be it.
looks like that's the 3.4 kit too. the 3.6 is 2k
Old 07-14-2016, 07:07 PM
  #64
Cuda911
Cuda911's Avatar
You could always go the KK route and fabricate all your own parts.
You could make all your own bolts and gaskets for less than $50.
Old 07-14-2016, 08:42 PM
  #65
Rich14428
Rich14428's Avatar
Beautiful car. Nice job on the rims too.
Old 07-15-2016, 01:25 AM
  #66
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
Originally Posted by centerisl
I assume this is from the upcoming guidance you've been hinting at. But...if it's simpler for a DIY, wouldn't that also carry over to shops that could then (theoretically!) charge less?
Shops charging less is called "cutting corners".
These engines will not get any cheaper to purchase without owners doing the work themselves.
Each year prices for these engines go UP, and not down. This will continue.
Cheap... Cheap.. Cheap..
If you can't afford to do it right the first time, why think that you can afford to do it again? People never listen till it happens. I gave up long ago.
That said, DIYr's stand by.
Quick Reply: IMS Tensioner Paddle failing?
