My 3.6 to 4.0 Project
#46
While they may not be needed, adding bigger cams and porting the heads is easier to do while the engine is apart. They are those "while you're in there" type upgrades . . . and how my STi's blown ringland turned into $10k+ engine build.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#47
Well, and it's not only well you're in there but the bigger displacement may/will demand it. Maybe it's my hangover but wouldn't running a shot of nitrous also take advantage of that extra space?
#49
Well there is putting it together as a nice running engine, which is very possible, and there is tuning it to take advantage of the new displacement which also is possible but more expensive.
Not saying one is better than the other, but may as well try and get the most out of it or at least more out of it than it otherwise would have been stock. So my vote is to have someone who is dangerous look at the heads and help with rings.
#50
Too bad the brand new factory crate 3.6 classified listing wasn't around when OP was in the decision making phase. $18k seems like a bargain these days considering Porsche is no longer selling the full long blocks and considering that is $18k OTD with no core required. He could've been running in no time with this option.
https://rennlist.com/forums/parts-ma...ate-motor.html
#51
that option was around when I was looking. 18kusd is more like 25k CND. I didn't even pay that for the car.
so far I'm about 9k cdn in. probably another 5-6k to go.
I'm sticking to my original plan.
#53
those engines are not stockers though. believe they are rebuilds with proper sleeves and pistons, lower thermostat, etc. if the price wasn't more than the car, I would have seriously considered it.
I looked at juSt replacing the engine with a stocker off of eBay but I have no gurantee I wouldnt be doing this all over again. with my luck with cars, it's pretty much guranteed to bite me in the a$$
#54
Former Vendor
We were just as busy back when crate engines were being sold new.. Back in the old days my engines were 15-18K and a new crate engine was 7-9K. More than enough people wanted the hand built, fully optimized version that was double, or sometimes triple the cost.
Its happening again today, as we supply my 4.2 and 4.4 for the 9a1 cars that are as new as 2014. People can buy a brand new crate engine for the new cars, or buy a hand built, fully optimized version.
The OP is looking for 300WHP, if he bolts this engine together as a 4.0 he will get close to that.
While "I am in there" I do everything I can. Overkill is just barely enough.
#55
honestly....I could care less about power. I want to be back driving this thing. I want it to be reliable. I miss it a lot. I feel a tear down my cheek everytime I see it hovering in my garage.
I use the same approach with all my car projects. get the car running reliably, then work on getting more power out of it. my projects are successful for the most part. I'm changing everything I can afford. everything that can be replaced is being replaced. I don't feel like I am taking shortcuts with this. I get that I should upgrade the head cams and all that while it's out but I don't have the funds for it, I've been told by the manufacturer it isn't needed and a divorce isnt in the cards
#57
lmao
and still reading. I'll pm you my questions as they come.
#58
I use the same approach with all my car projects. get the car running reliably, then work on getting more power out of it. my projects are successful for the most part. I'm changing everything I can afford. everything that can be replaced is being replaced. I don't feel like I am taking shortcuts with this. I get that I should upgrade the head cams and all that while it's out but I don't have the funds for it, I've been told by the manufacturer it isn't needed and a divorce isnt in the cards![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
If funds are an issue, why would you go to a 4.0L anyway?
You could have done a nice nickies 3.6 with a fully optimized package that would likely perform better and last longer than a compromise 4.0.
