My 3.6 to 4.0 Project
#348
#349
I do but it crapped out on me and keeps giving me errors communicating messages. I'll have to write to their support line...
#350
#352
and i see some other codes pending also...these are new p0300, p0301, p0304
I thought there was some slight stumble going on while cruising around 3k rpm.
I really need to get my durametric working
#353
So they are all misfire codes of some flavor. I don't know much about the ECU on these cars does it take some time to relearn for the larger engine bore and various mods?
#355
You need at least an OBDII scanner that can read sensor values in real-time to track the following:
- Coolant temp
- MAF
- Short term fuel trim (RKAT in Durametric)
- Long term fuel trim (FRA in Durametric)
- Voltage of all 4 O2 sensors
- Coolant temp
- MAF
#356
FYI, I had to restore my laptop to factory default Windows load and reinstall Durametric software to get it working again. You might try it on another machine if you have something you can drag out there.
#357
My garage found the leak. Unfortunately he is recommending I drop the engine to fix it. I'm not sure that's necessary.
He is spraying around where the intake manifold meets the block and the car's idle drops as soon as brake clean is sprayed in that area.
#358
Get VirtualBox (free) and run Windows in a VM specifically for Durametric. Much less hassle when something happens as you don't have to blow away your personal stuff. Also means that whatever you do to the desktop OS is much less likely to screw with the Dura install
#359
Good idea. I'm using a spare Surface II pro that needed to be wiped anyway but it makes sense to have 996 VM for the collection of outdated tools I'm amassing.
