blown engine
#841
Thanks guys! More pics
New flywheel on with two hand made lock tools at 10 and 3 o'clock for tightening the flywheel bolts 120 degrees after ftlb torque spec
Clutch disc reused as it looks like brand new.
Current state
Current state
#842
Beautiful engine, looks like you are completely done now with this complete engine rebuild, even better than new from Porsche :-) Amazing work, you did on this engine... Now you should put this brand new engine in your own 996 and enjoy it, heh heh heh, cheers.
#844
Made a jumper switch to plug into the fuel relay socket to drain the 2yr old gas. Works like a charm. I also monitored the fuel level in real-time via durametric. Pretty cool.
#845
Good plan to drain & refill the fuel .I also changed the filter.
Your audience may be interested to learn about the best after-rebuild 1st start procedure.
Future rebuilders will be grateful for the hi-res photos because they show where all the hoses and wires should go.I had to resort to looking at photos on EBay of used M96 engines for sale ! You have done the M96 community a great service Duncan. Thank you !
#847
Ideally but on MkII 996's the fuel filter is part of the fuel pump so unless I change out the fuel pump...
#848
Did you know there is a future for Duncan as a Singer?
I found a new gig for Ahsai:
http://jalopnik.com/meet-the-master-...sin-1791648854
8 hours work on a new cylinder head ? They must have some small amount of Raby DNA?
#849
That engine is a piece of art...at least the m96 shares the same oil pressure sensor, which is crap btw
#850
#851
Received 1,896 Likes
#852
#853
It's alive!!
Using the technique Jake described. You can see the oil pressure build up crank after crank. It took only 3 seconds of cranking to get the engine started, compared to the normal 2s so it's not bad.
#854
I've done many types of engine from aircrafts to 80 liters and on down.... always great to hear it fire but with my heart in my throat for first start. excellent job
