IMS Class Action August 3rd Update. New Claim form Claims Posted
#271
what about those who purchased a re-man engine in 09 for their 996? I know the re-man engines are suppose to have updates but if we get an IMS failure on one of these new reman motors then what?
I would imagine this class action suit is setting precedent no?
#272
That engine would have come with a 2year, 24000 mile warranty and the larger upgraded bearing. Failure incidence appears to be significantly (though not 100%) lower.
#273
Nedster, you need to look at the settlement agreement to be certain, but as I recall, due to the age of your car at the time of failure, you are in the 25% recovery class .
#274
This class action will not cover the reman engine failing, but it covers the original engine failure which caused the re manufactured engine to be installed, assuming the original engine failure was IMSB related.
#275
Here in Canada we can sue in small claims court for up to $20K - given the IMSB has been well documented and even associated with a class action law suit in the USA will provide substantial grounds for any reman failed IMSB.
#276
You can duplicate the efforts of the class action attorneys who were paid $950,000 to satisfy that burden of proof, or you can take a shortcut and ride along on their effort and review their discovery documents.
That fact your engine failed proves nothing. You need to prove the failure was caused by a defective design, and that won't be easy on your own.
#277
I'm not clear on the VIN ranges and the 8th digit being a 'check digit'. Using my browsers search, I type each character, but it can't match past WP0AA299 - which seems to mean that VIN WP0AA29984S621365 is NOT included even though it's a 2004 - is that true?
#278
#279
+996 and the reason why this suit doesn't really mean anything to me.
#280
Just found out about the settlement and it looks like my VIN is listed, WP0CB29825S730547. I have an '05 Boxster S with 38kmi on it. No problems yet.
How do I make sure I'm covered if my IMS fails in the next couple years?
PS: See next post, trying to properly decode VIN.
#281
Initially I thought I was covered but perhaps not. VIN is WP0CB29825S730547. As I understand it the last 7 digits determine the factory and serial number, which should give a mfg date. Is this correct?
From the IMS VIN list it looks like the last serial number for the Stuttgart factory is S6660555 where mine is S730547. It's a '05 987 Boxster S with 38kmi and no IMS issues so far.
#282
I also have an 05 Boxster S outside the VIN range. It is a May 05 build date at Stuggart. There has been much discussion that the mid to later 05's got the newer upgraded IMS, so we can speculate that is why we are not included.
Does that mean increased reliability? I can only hope so. I purchased my privately so even if it were covered it would be 25% at best, but since I am in Canada it does not apply. Oh well spring time and looking forward to some more driving.
speakerdesign, my VIN is close to 100 after yours, almost twins!
#283
I have read all the pages on this thread, but I am still confused on what I should do. I am the original owner of an '04 40th AE now with 39,xxx miles. I have not had RMS or IMS failures, in fact, no problems at all. I visited the site today for the first time in years.
My VIN is WPOAA29974S621003. First, I cannot tell if I am in the class or not. Second, since I have not had any problems, do you recommend going to my local Porsche dealer for any sort of inspection or preventative maintenance? I am not sure what single row or double row bearings refer to. From what I read here, the single row bearings are more robust? Third, my in-service date was December, '03 -- so I guess this means I have six months to see if I have engine problems? (Or only until the lawsuit window closes?)
I don't track the car, but do take it on occasional long, overnight highway drives through some rural areas...and my wife and I would hate to be stranded. If my '04 AE is one of the 10% manufactured that evidently has this problem, and I am approaching the 50,000 mile mark, what is your advice? From what I have gathered, there are "third party" solutions out there (probably installed by an independent shop) -- would that make sense? What does that cost? Or can my regular dealer handle? Sorry, I am probably the least mechanical owner on this board, but I love the car and intended to take it to my grave. Until tonight. I appreciate your advice and assistance.
#284
Porsche Nut
FYI: I also love my AE. I plan on keeping it too.
