Questioning the reliability of the 996 (starting problems) + Fuel Vent System(PICS)
#76
#78
#80
Another update after driving today... the car started and drove fine but as soon as i would let my foot off the gas pedal the howling noise would start and as soon as i stepped back on it the howling went away. I saw there is a positive intake manifold draw tapped from the EVAP canister, any ideas why it would make this noise behind the gas cap though?
Where are my fuel vent specialists?
#81
Hope this helps.
link to RennTech
1 - EVAP canister purge valve
2 - EVAP canister
3 - Purge air
4 - Tank
5 - Pressure sensor
6 - Shutoff valve
7 - Operating purge valve
8 - To intake manifold
9 -Vacuum control valve
link to RennTech
2 - EVAP canister
3 - Purge air
4 - Tank
5 - Pressure sensor
6 - Shutoff valve
#82
This might help. Got it from a old thread on RL.
http://www.pelicanparts.com/cgi-bin/...1999-05)%20%20
I did a google search and the RL post showed up. Hope this helps.
#84
I did a search for "EVAP canister purge valve". That is what came up. I'm not a mechanic by no means and it does appear to be at the throttle body per the diagram.
I suggest doing a search here on RL with those key words. Not to be short Ryan.....but if I can find this stuff so can you....
Good luck!
Good luck!
#85
Trust me I usually try a search prior to me posting. I cant find anything on the EVAP canister.. I posted in Renntech, maybe they have some ideas. I've seen other guys with the same problem as me though. I'll post updates.
#87
Hope this helps.
link to RennTech
2 - EVAP canister
3 - Purge air
4 - Tank
5 - Pressure sensor
6 - Shutoff valve
link to RennTech
2 - EVAP canister
3 - Purge air
4 - Tank
5 - Pressure sensor
6 - Shutoff valve
does anyone know the functional purpose of the purge valve (#7)?
