question about window regulator and switches
I have a friend's car (02 996 C2) that is having an odd issue that I didn't come across a solution when searching, and I'd like to see if someone has had the same problem.
The driver's side door, when opening it from either the outer handle, or the inner handle, will lower the window the appropriate distance, but will then immediately raise the window back up, even when the door is opened, or even when the handle is held open. The "car" seems to think the door is not open, because the dome light will go out after a bit, as though the door was shut, even though the door is actually open. That's the first issue.
A second thing I notice is that when trying to close the door, because the window is not lowered any longer, it has to snap into the seal, which seems to have loosened the window.
Does this up/down action and inability to recognize that the door is open, sound like a microswitch problem, or a regulator problem? Seems like the switches work, but something is not registering the proper function. Otherwise the function is normal for the roll up and down; it just won't stay down in the required spot, and the car doesn't realize the door is open with it actually is.
Pointers? I'll try the "reset" maneuver tomorrow to see if that helps. Thanks so much for any other ideas from those that have come across this issue.
Good luck with the repair!
Thanks for the help.
The other switch I bought, could work as a replacement by epoxying it into place if an entire switch is required. Its part number is: SW291-ND
Thanks again,
Dan
