Time for and updated baby seat model thread? Past threads have outdated names, etc.
#362
I understand the bubble bum, and the red restraint to position the shoulder belt correctly it your previous pic. rear seat pic looks to need a booster to position the shoulder belt correctly, and could you explain the vest first I've seen.
#363
http://safetrafficsystem.com/ver4/
The vest is an alternative to a booster seat. Just like a booster, the vest basically adapts the stock belts to fit a child and be effective.
#364
Hi chaps, I've got an ageing 996 Cab C4 9.4L and I'm hunting around for a car seat for a 1 yr old which i intend to use in the rear seat.
I've been doing lotsa reading which has been complicated as some of the posts are 8 yrs old and the models are no longer offered. However I think I've narrowed down to a few here :-
1) Britax Roundabout (which one? there's 50 classic and 55)
2) Porsche Junior Seat G1
3) iZi Comfort X3
I did research other models and brands such as the Britax Evolva 1-2-3, Duo Plus & Recaro Young Sport which wasn't a guaranteed fit, Two-Way Elite which was too upright, Maxi Cosi Rubi & Tobi which looked to be too high, Nania Trio Plus which had a recall.
For the 3 seats above, could someone please confirm :-
a) they fit in the back of a Cab C4 as they're narrower than the standard coupe?
b) is the ISOFix base used or only the 3 point seatbelt?
Thank you
3) iZi Comfort X3
Thank you
#365
3) iZi Comfort X3
Thank you
3) iZi Comfort X3
Thank you
I don't know the laws in Japan but over here you can't put a 1 year old forward facing - they have to be rear facing in a convertible seat or infant seat till around 2 yrs old. The only rear facing infant seat that works well is the Cybex Aton (do a search on Cybex Aton Porsche 911 - you'll see it in action in youtube)
The only forward facing seat that worked for me is the Porsche Junior seat. Others have tried various recaros etc that seem to work for them - look for posts on this thread from the past year - they're all current seats.
#366
nc911
our cars look almost identical
Shearlayer
I can't seem to find a supplier for the maxi cosi Rubi. I found the other models made by maxi cosi but not the rubi.
Do you mind sharing a link if you have?
Never mind I found it on ebay. here is the link
http://www.ebay.com/itm/MAXI-COSI-RU...item3f26563582
Shearlayer
#367
You can't use ISOFIX as there's no anchor in a 996 to connect it to. You have to use seatbelt to secure the seat.
I'll also read up on Cybex Aton. I've not heard of that one before.
Thank you.
#368
A convertible seat (one that is both rear facing and then converts to fwd facing) is Maxi Cosi Rubi - some people say it fits - I have NO idea if it does...
Personally I used Combi Coccorro as my convertible car seat, but then when my son was big enough to be forward facing I bought the Porsche Junior seat
Here's the Combi Coccorro I fitted in my car:
Here's the maxi cosi in a Porsche:
and finally here's the Porsche Junior Seat in my car - the most secure fitting one I have found:
https://rennlist.com/forums/996-foru...or-my-son.html
#369
[snip!]and finally here's the Porsche Junior Seat in my car - the most secure fitting one I have found:
Looks like Japan doesn't have the requirement for 1yr + (or under 2 yrs to be more precise) to have rear facing. Only under 1 yr needs to be rear facing.
Edit: for my son's 1st year he used (in fact still using) a Maxi Cosi Pebble, installed in the same way as yours.
2nd Edit: Porsche Junior Seat ordered. Thx again chaps, for the guidance!!
#370
@Roadsession, that is excellent. I've never seen the Porshe Junior Seat set in a 996Cab before so those pictures are very useful. I think your post has helped me make up my mind to go for it.
You can still check eBay - they come up once in a while
If not the new model fits fine too it's also called Porsche Junior seat.
Also I removed rear seat back - you gain valuable inches
#371
http://www.design911.com/Porsche-Jun...8-kg-/prod422/
It doesn't have the front padding protection which your older model has. Not too sure why that was dropped 'cos I would have thought that front padding protection was a good idea. I guess I'll just see how it goes when it arrives.
#372
I ordered the following in the end :-
Anakchan - my son refuses to go in my wife's BMW - sometimes we have to take 2 cars because he wants to go in "daddy's Porsch-ah"
#373
I have fitted both the Cybex Aton (better quality) and Graco Snugride 30 (cheaper) rear-facing into the back seat of my 2009 997.2 cab without using the base units.
I removed the rear seat squab to give more room, as it is only velcro'd in place.
The front seats will not go back properly if the base units are used.
I can still get a small adult in the front passenger seat in with either baby seat fitted.
#374
Are many people replacing the factory seat belt bolts with eye hooks and installing the seat with the latch belt? It seems like this would be more secure, or at least more rigid, than factory retractable belts. I'm going through the child seat exercise now, but I don't see this mounting method discussed much.
#375
Now the base stays in the SUV because there the convenience is more important than the space.
