996 Forum 1999-2005
Oil Wars, Revisited!!!
Old 02-20-2008, 12:37 PM
  #91
wross996tt
wross996tt's Avatar
Why don't you guys go debate this on this forum:
Bob Oil Guy
perhaps some of you will stay there.
Old 02-20-2008, 12:45 PM
  #92
Blackness
Blackness's Avatar
Yeah, I figured I would ask the question in a straightforward way. But not really expecting a rational answer. More like some psychotic assertion that implies he knows more than god.
Old 02-20-2008, 05:20 PM
  #93
pat056
pat056's Avatar
Hey!! I'm ashamed of all you guys!! An oil debate, and we can't even get 100 posts?? What's the world coming to?
Well, I've done my part. It's now 92
Old 02-20-2008, 07:49 PM
  #94
dresler
dresler's Avatar
oil shmoil.
Old 02-20-2008, 08:24 PM
  #95
AndyK
AndyK's Avatar
I'm getting my oil changed tomorrow. Porsche recommends 0w40, and 5w40. I figure since I don't drive my car as much as I should, 5w40 will be a better lubricant during cold starts. When the car warms up to operating temps, the first number means nothing and the 40 kicks in, same as 0w40, right?
So, it looks like 5w40 will be my oil (and Porsche's) of choice!
Old 02-20-2008, 10:07 PM
  #96
dresler
dresler's Avatar
Actually 0W is better during cold starts, you want the oil to get pumping as quickly as possible when the engine is cold, and you are pulling it out of the sump. especially in NJ where it really gets cold.
Old 02-20-2008, 10:13 PM
  #97
AndyK
AndyK's Avatar
Hmmm, I thought thicker oil protects better. Guess I'm wrong. Why do people call 0w40 Mobile water?
Old 02-20-2008, 10:34 PM
  #98
dresler
dresler's Avatar
The W in the viscosity stands for "winter." When the engine is cold, a single viscosity oil (say, 30 weight) would be way too thick when cold to be pumped effectively by the oil pump, and would take too long to enter tight tolerance areas. The upper sections of the engine would also be oil starved, and excessive wear would result. The only reason for multiple viscosity oils is to provide protection when the engine is first started and is cold.
Old 02-20-2008, 10:53 PM
  #99
1999Porsche911
1999Porsche911's Avatar
A 5W oil is good for cold starts all the way down to -15F which is far colder than you would likey get in New Jersey.
Old 02-20-2008, 11:02 PM
  #100
AndyK
AndyK's Avatar
And would the 5w40 protect better than a 0w40, once the engine is warmed up?
Old 02-20-2008, 11:27 PM
  #101
1999Porsche911
You don't get higher shear protection in a 40 weight oil until you move to a 15W40. If you want to use a 5W oil and get additional protection when the oil gets hot, move to a 5W50.
Old 02-20-2008, 11:34 PM
  #102
wross996tt
wross996tt's Avatar
It is time to dispel the notion that 0W-30 oil is too thin when our manual calls for 10W-30. A 0W-30 is always the better choice, always. The 0W-30 is not thinner. It is the same thickness as the 10W-30 at operating temperatures. The difference is when you turn your engine off for the night. Both oils thicken over the evening and night. They both had a thickness, a viscosity of 10 when you got home and turned your engine off. That was the perfect thickness for engine operation.
This from a Ph.D. read my earlier link please...it is full of substantiated information and data...not just opinion and emotion.
Old 02-20-2008, 11:39 PM
  #103
wross996tt
wross996tt's Avatar
Uh NO you are wrong:
From SAE J300 p.2:
"Two series of viscosity grades are defined in Table (1): (a) those containing the letter W and (b) those without. Single viscosity grade oils with the letter W are defined by maximum low temperature cranking and pumping viscosities and a minimum kinematic viscosity at 100C. Single grade oils without the letter W are based on a set of minimum and maximum kinematic viscosities at 100C and a minimum high shear rate viscosity at 150C. The shear rate will depend on the test method. Multigrade grade oils are defined by both of these criteria....
The W is just a designation of one type of testing vs another. I personally asked them if it stood for "winter" and they flatly said "no".
stop making up stories you know nothing about.
Old 02-21-2008, 09:54 AM
  #104
Tippy
Tippy's Avatar
Then you need to educate a lot of auto instructors and change auto mechanics books throughout the US because I was taught the same as dresler at an early age.........course these books and instructors also talked of warped rotors....... hmmmmm
Old 02-21-2008, 11:15 AM
  #105
wross996tt
wross996tt's Avatar
Blind leading the blind...I guess that makes it right...someone reads a post on here and thinks it is fact...next thing you know it is published in books (please post the reference)YOU really should read the link.
Quick Reply: Oil Wars, Revisited!!!
